Brake Booster
caveman7216
Brake Booster
Postby caveman7216 » 11 Jul 2011 22:52
Brakes on car go to the floor, then after pumping them, they get stiff, does anyone know what this is
Postby DNK » 11 Jul 2011 23:01
Could be a few issues.
Bleed them first
"No More Cars For You"
71 TR6- Perpetual remodel
Postby jclay (RIP 2018) » 11 Jul 2011 23:52
Probably air in rear brake lines.
caveman7216
Postby caveman7216 » 12 Jul 2011 18:55
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by caveman7216</i>
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">brake still have problem after bleeding,now brake light is on. just replaced master clyinder, and plastic pressure switch.
Postby DNK » 12 Jul 2011 20:08
Did you bench bleed the master.
Do these have a PWDA as in the 6?
HDRider
Postby HDRider » 12 Jul 2011 20:57
To bleed the system you must first remove the plastic switch.
A worn out balance valve can make it impossible to bleed the rear brakes. Rimmers sells new one for about £40. I have replaced all valves in my three cars.
Edward Hamer
Petaluma CA
Postby bmcecosse » 12 Jul 2011 21:00
I've asked this before - and not had an answer, but does the car really NEED the horrible 'balance valve' ?? My Mini had much better braking after I threw it's balance valve over the hedge......
Postby saabfast » 12 Jul 2011 21:01
[/quote]
When you say 'brake light is on' do you mean the warning light or the rear barke lights? When bleeding the brakes the brake failure warning light 'switch' in the bottom of the master cylinder should be removed.
If it is the rear brakelights, I have had these stay on permanently before after changing the M/C. It was the the bracket holding the brakelight switch above the pedal which can get bent replaceing the master cylinder.
Saab 9000 2.3 FPT Auto
Postby DNK » 12 Jul 2011 23:31
Here's a question.
Richard good is selling a dual master cy. kits for the TR6. Suppose to be not that heavier on the peddle and quicker action of the brakes.
Now the 6 can't be much different than the Wedge.
What do you think about getting rid of the booster on these?
http://www.goodparts.com/shop/index.php?categoryID=35
Postby Odd » 13 Jul 2011 08:29
Maybe legal in America - but would definitely be illegal over here.
I wouldn't tamper with the brake master - I'd see to it that it was fully functional as design intended
before anything else. 30+ years is a lot...
Postby PeterTR7V8 » 13 Jul 2011 09:39
The proportioning valve diverts brake pressure away from the rear to stop them locking up - the harder you jam on your brakes the more the pressure balance goes to the front. All good with standard brakes but if you upgrade your front brakes then you don't need the valve because the front wheels will probably lock up before the rears anyway.
Users browsing this forum: No registered users and 114 guests
