That dreaded feeling.
claypole1360
Postby claypole1360 » 30 Jun 2011 20:34
Popped into Halfrauds for an oil filter for my V8, on the way to the petrol station the car died completely, (400 yards from my house but a set of lights and two 90 degree bends away). Worse still, there was smoke in the cabin and burning odours, I lifted the bonnet and it was clear, I fumbled under the dash and it was clear, there was absolutely no melted wires, nut no electrics at all to anything.
After being barked at by a passing constabulary representative that I couldn't use the tow rope I was planning to use, illegal now apparently, I resorted to the AA membership card and they turned up within 20 minutes, decided to tow it to my house and set about it.
His words, "sort the wiring and you'll have a fantastic car"
The source of the problem was really quite scary, The positive feed from the boot to the front of the car has to travel through three bulkheads, two of them had grommets, but one of them had collapsed, and one hole had none. The collapsed grommet had chafed through and was shorted out through the body. Hence the smoke and the now destroyed battery.
My next job then is to widen the holes in the bulkheads and put some proper sized grommets on them, I also have to reroute the cable around the engine as it currently chafing on the steering column.
This is a voyage of discovery for me and it may be a while before I can trust the car over a distance, still, it looks great and goes like stink.[8D]
Calvin
Postby Cobber » 01 Jul 2011 09:06
I don't waste time with mere grommets I prefer to use proper cable gland fittings these days!
85'Alfa 90, 69'Ford F250.
claypole1360
Postby claypole1360 » 01 Jul 2011 14:08
Nice, where in England can we get those?
Calvin
Ianftr8
Postby Ianftr8 » 01 Jul 2011 16:47
Any electrical wholesaler or B&Q or Wickes should be able to supply these
A very good suggestion
Ian
Ian Freeman
1962 Triumph Courier
SimonO
Postby SimonO » 01 Jul 2011 18:51
Calvin - As you know I normally would love to gloat...
However, my car is at the auto electricians having the entire loom checked and all the ends remade etc. [V]
http://persistentworktriumphs.blogspot.com/
Postby bmcecosse » 01 Jul 2011 22:24
Tow rope should be fine for an 'emergency' recovery - the cops have a cheek..... You were lucky the battery didn't actually explode - and cover the boot area with acid. It may have destroyed the alternator too......
claypole1360
Postby claypole1360 » 02 Jul 2011 09:37
Simon, I am considering a new loom, for peace of mind really, I think I will be chasing someone else's mistakes otherwise, let me know how you get on.
As for the battery, I am lucky, and the alternator has been checked and is working. I consider myself quite fortunate. Calvin.
SimonO
Postby SimonO » 02 Jul 2011 10:48
I did get a complete 2nd hand loom from Robsport - and handed that to the auto electrician along with a towbar, spare dash and various other spares.
They are going to remove the old loom completely, put the new one in and replace every connection as they go. Where possible they will improve the loom for the spotlights, stereo etc.
It's not going to be cheap, but hopefully it'll stop the annoying intermittent failures. I could have done a lot of the work myself, but late nights due to the day job and busy weekends meant this would have taken months.
Then it's only a new mohair hood and some minor bodywork tidying to go. (Fingers crossed).
Users browsing this forum: Google [Bot] and 72 guests
