Gearbox Mounting
Gearbox Mounting
Postby REPLIC8 » 19 Jun 2011 11:52
How much flex should there be in the gearbox mounting? Mine as solid as a rock, If I try to move the box with a jack it raises the car up, there appears to be no flexibility at all.
Postby nick » 19 Jun 2011 13:32
The box is bolted through the cross member. See the picture I posted under your oil seal post. The mount is rubber but extremely hard. Not meant to move, only to damp vibration.
'79 TR7
Postby busheytrader » 19 Jun 2011 13:55
Hi Andy,
My old oil soaked item was as hard as a Jelly Baby when I removed it.
The replacement had about as much give as a block of wood. I heard rumour that a batch of over hard gearbox mounting rubbers hit the shops a couple of years ago. More gearbox whine came into the car afterwards, and more again after changing the remote housing bushes to poly spec.
Users browsing this forum: Google [Bot] and 66 guests
