exhaust manifold
rocky_679
exhaust manifold
Postby rocky_679 » 07 Apr 2011 20:33
just a querry in the workshop manuals it says gaskets 4 the exhaust manifold are not needed yet rimmers an eveery one sells gaskets for the manifold is ir best to use or not use as im changing from cast iron to stainless steel ???
stephen j dark
staningrimsby
Postby staningrimsby » 07 Apr 2011 20:38
I went for a stainless manifold during the conversion Rocky and as a matter of course its better to spend the £10 and get the gasket, two metal surfaces mating together will not seal properly.
1980 2.0 16v DHC - Polly.
Postby john 215 » 07 Apr 2011 20:44
The gaskets were originaly for F.I TR7's the carb engines ran nothing, but if you fitting a stainless manifold then i would rec them everytime.
Postby FI Spyder » 08 Apr 2011 02:02
In fact it's common practice (recommended) to use the
FI gaskets on all exhausts regardless.
bahbzilla
Postby bahbzilla » 08 Apr 2011 13:07
I wondered the same thing when I rebuilt my motor. Everyone I talked to said that TR7's (non-FI) and Stags came from the factory with no gasket. Everyone also said that they did add one if they pulled the manifold and found none...
Bob
1980 TR7 DHC
Postby Hasbeen » 09 Apr 2011 00:01
I took Triumph at their word, & have never used s manifold gasket. On each of the 4 I have fitted I used a smear of the red high heat silicone goo, with complete success. I do use a home made gasket on extractor exhaust systems when I have them fitted, as I have found they often distort when hot.
When it comes to the manifold flange gasket, on the stock manifold, which does have a shim gasket, it's an entirely different story. I have always had to replace the studs, & make a gasket out of klingerit to get a satisfactory, long lasting seal.
rocky_679
Postby rocky_679 » 10 Apr 2011 16:36
well fitted the gaskets to the manifold now im modifying the exhaust having a straight thru exhaust no centre box just big bore tail pipe i did it on the last 7 as it was rotten an garage said i didnt need 1 so they did last 1 took away the centre box an it ran fine sounded louder tho somthing to wake up the neighbours [:D]
stephen j dark
Users browsing this forum: No registered users and 46 guests
