Spax nut size
Vegas_M
Spax nut size
Postby Vegas_M » 30 Mar 2011 23:10
Hi all,
I have a used set of adjustable Spax strut inserts that I want to use, but am missing the nuts at the top of the shaft that holds the springs and cap to the strut assembly.
I thought they were metric 12x1.25, but they don't fit (too tight). I also tried 1/2 NF, but they don't fit either (too loose).
Anyone know what is the correct nut for the top of the strut?
Thanks,
Martin
Martin
Postby DNK » 30 Mar 2011 23:25
Try 12 x 1.5
"No More Cars For You"
71 TR6- Perpetual remodel
Vegas_M
Postby Vegas_M » 31 Mar 2011 12:50
OK solved.
The original Woodheads I took out used a 7/16-NC nut. A quick glance showed the spax were different, and closer to 1/2". I did try a metric 12x1.5 but it was way too coarse.
So, it turns out the previous owner (I guess) tried to put the wrong nuts on these strut inserts and bunged up the top of the threads a bit (close inspection with my bi-focals on - ahh old age). This is why the "correct" metric 12x1.25 nuts wouldn't go on. I cleaned up the threads with a metric die, and viola, they screwed on and tightened down fine.
The joys of old cars and pre-used parts....
M.
Martin
Postby DNK » 31 Mar 2011 13:25
Ah, NUTS
Marko
Postby Marko » 01 Apr 2011 11:10
Users browsing this forum: No registered users and 395 guests
