Modified front brakes
dycecooper
Postby dycecooper » 27 Feb 2011 10:21
My car has AP bells and disc (in poor condition)
Calipers are AP 4 pot ( also in poor condition)
Do I re furb them? or start again? whats available?
I have Bilstien struts but I dont thing that should make a difference.
ANy thoughts and opinions would be good to hear.
Postby TR Tony » 27 Feb 2011 11:28
I have got AP 4 pots with AP vented discs on my 2L coupe, it stops very well even with a standard master cylinder/servo.
If you have separate discs mounted to bells, my first thought would be to refurb the calipers, & just replace the discs.
However I know AP discs can be expensive. I found this firm to be very knowledgeable & helpful about all things AP:
http://www.bgdevelopments.co.uk/
Postby john 215 » 27 Feb 2011 11:36
If you get the parts at a resonable cost and safe to do so i would recon them as something a little different to the Capri or Princess set up.
dycecooper
Postby dycecooper » 27 Feb 2011 12:13
Thanks for the link Tony.
Yes john I agree.
dycecooper
Postby dycecooper » 27 Feb 2011 17:43
I was having a look online today at various options and although my calipers are AP I think they may well be just Princess AP calipers, if that is the case then I will be looking at replacing them.
trsforever
Postby trsforever » 27 Feb 2011 18:27
Hi
If calipers are AP steel 4 pots they could be princess with 245mm
disc which was a Rimmers kit or SD1 rover 260mm disc also from
Rimmers, 3247 is the number on my princess ones, if you want
new have a look at this site www.hispecmotorsport.co.uk and look
at brake kits/Triumph they have 260mm disc and ali 4 pot caliper
kit for under £400 but check for wheel clearance.
Good luck.
Regards Scott
Postby john 215 » 27 Feb 2011 20:20
Poss Princess calipers, but how many brake pipes have you got going into the caliper ? The Princess has 2 and 3 bleed nipples.
dycecooper
Postby dycecooper » 27 Feb 2011 20:59
There are two pipes going in, nead to check how many bleed nipples
Postby john 215 » 27 Feb 2011 21:13
Sound like Princess calipers, they have a bleed nipple on each side in the middle and one at the top.
willywonka
Postby willywonka » 28 Feb 2011 09:41
Try contacting Ian Godney at Godspeed brakes in Bridgend, South Wales. He specialises in performance braking and can supply you with replacement rotors and he can also overhaul you calipers as well.
01656 723060
http://www.godspeedbrakes.co.uk/
All the Gear, no idea
dycecooper
Postby dycecooper » 28 Feb 2011 14:31
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by willywonka</i>
01656 723060
I have called them, very helpfull indeed, thanks for that.
dycecooper
Postby dycecooper » 04 Mar 2011 16:11
I looked at skimming the Discs I have and re-furbing the calipers, but I was not happy with the pads, its the correct pads for the calipers but then ground out a bit to clear the AP bells.
I have ordered new discs, callipers and pads.
Photos to follow when I get them.
dycecooper
Postby dycecooper » 14 Mar 2011 18:35
New brakes arrived today [:)]
dycecooper
Postby dycecooper » 14 Mar 2011 18:38
The Brakes fitted no problem but the New hoses don't match up so quick call tomorrow to order what I need.
Then I wil tidy up the Princess calipers, AP alloy bells and discs and sell them.[8D]
Postby john 215 » 14 Mar 2011 18:43
Very sexy [:D] almost to good hide behind wheels.
Users browsing this forum: No registered users and 170 guests
