Loose steering column
whitenviro
Postby whitenviro » 10 Feb 2011 18:32
It's clear cold and dry here lately, so I've had the car out. In the cold there is a symphony of new squeaks and rattles that weren't there in warmer weather! But the biggest surprise was the entire steering column slid to the side on a hard turn. The bracket where it mounts to the dash is too loose and it is held in place with shear-head bolts. The manual gives a pretty bad description of how to get the bolts out, and no idea if you can tighten them more. Any suggestions?
[/img]
Postby PeterTR7V8 » 10 Feb 2011 18:36
You can tighten them but in my experience they are likely to become loose again because the very shallow notch makes it is difficult to get them really tight. After a while I got tired of this & replaced them with normal bolts & haven't had a problem since. I'll probably regret it next time I have a big smash. [:0]
Postby Beans » 10 Feb 2011 18:39
Difficult to retighten them properly, best to remove them with a hammer and a centre punch.
Adapt some Allan head bolts on a lathe and use these instead ...
staningrimsby
Postby staningrimsby » 10 Feb 2011 18:42
I'm with Peter,
when mine got on my nerves i replaced them with normal bolts and a touch of thread lock.[:)]
1980 2.0 DHC (soon to be 16v) - Polly.
Postby FI Spyder » 10 Feb 2011 20:47
To take them out and put them back in I just put a slot in them with a Dremel. Tightened them up and no problems. I probably used some Locktite as I usually use it.
whitenviro
Postby whitenviro » 28 Feb 2011 05:34
I finally got around to this today; thanks for all the suggestions. The dremel and a small cutting wheel did a nice job putting a notch in them, and they came out easier than I ever expected. Replaced them with new cap screws that fit nicely. Firmed things right up!
[/img]
Postby PeterTR7V8 » 28 Feb 2011 06:30
At our age that's got to be a good thing. [:)]
Users browsing this forum: No registered users and 377 guests
