Rear shock dimensions
tencate
Postby tencate » 29 Dec 2010 04:25
I just tried a set of "stock" rear shocks from VB (stamped Made in Thailand with VB's part number on them) that I've had sitting around for a while and they feel like they're bottoming out so I put the old KYBs back on. I looked through the archives here and noticed that Beans noted that both Spax and Avo's are too long and bottom out in the shock as well.
If Rimmers is selling County rear shocks, those are the same dimensions as the ones I have here from VB.
Anyone have an ORIGINAL rear shock (was it Armstrong?) and can give us the closed and open dimensions (don't include the threaded parts at the ends)? I should take off those ancient Monroe shocks (1194 I think) on my other wedge and measure those dimensions and compare I suppose.
Thanks,
Jim
Stag76
Postby Stag76 » 29 Dec 2010 08:18
After reading somewhere on this Forum, I fitted some Monroe 31125 Rear Shocks. They were originally specified for Ford Customline, Ramblers and 60's Corvettes, and give a really good firm ride with no bottoming out.
TR7 Convertible
Sprint Motor
MegaSquirt EFI
tencate
Postby tencate » 29 Dec 2010 14:46
Ah, that may have been me via Clay. My friend Phil (TR8 FHC) has these same rear Monroes on his (with KYBs on the front) and he <b>really</b> likes them as well. They do bottom occasionally on his car though but only once in a while. Still hoping to find a set of Konis lying around gathering dust in someone's warehouse I can snag.
Postby Beans » 29 Dec 2010 15:13
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by tencate</i>
... Still hoping to find a set of Konis lying around gathering dust in someone's warehouse I can snag ... <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Good luck [:D]
Measurements on the Koni's are;
• Closed 301 mm;
• Open 484 mm.
As stated in my weblog they function fine, without bottoming out.
That's for the axle's bump stops
frankman
Postby frankman » 29 Dec 2010 15:46
hello Beans can you give me the Koni deliver immediately [:D]
Hello from Switzerland
Frank
Postby FI Spyder » 29 Dec 2010 16:21
My Koni's are still going strong. Too bad they don't list them any more. Are there a set they make that can be substituted?
Valving wouldn't be as important as open and closed position and end type.
Postby Beans » 29 Dec 2010 16:51
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by frankman</i>
hello Beans can you give me the Koni deliver immediately ...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
The pictured shocks came free from a friend, when he was clearing out his magazine (ex BL/Rover dealer)
Marsu
Postby Marsu » 29 Dec 2010 16:55
Here in Australia we can usually get Konis rebuilt without problem.
I found that with 2" lowered rear springs I had to have the extended length shortened to ensure the springs could not come out at full extension. (Of course, one could also fit a spring retainer plate as an alternative.)
Users browsing this forum: No registered users and 154 guests
