Brake Rebuild
cozyheatdave
Brake Rebuild
Postby cozyheatdave » 11 Dec 2010 15:18
I know this subject has been repeated too many times. But, first the search on this site is the ONLY thing on "The Best Triumph TR7/8 Forum On The Net" that I really don't like. It simply wont' work.
Anyway, back to subject. I have the front struts on the bench, ready for brake rebuild. Not shown is the new rotors. Everything will be new and mostly stock TR7 except the Green pads.
Where do I start? Does anyone have a step-by-step guide?
Thank You in advance for all the help !!!!!
Here's the layout...
One questions is how do I get the greenish goo off the spindles?
Is there an O-Ring for this spot? I can't find one in my rebuild kit?
Here's some close-ups of what I have from Rimmers...
elsberry
Postby elsberry » 11 Dec 2010 16:45
That greenish goo is Cosmoline, or some other waxy / petroleum based preservative. I take 'less than large kitchen pot sized items' and simply boil them in the kitchen in water (in a pan that someone in the house WON'T kill you for using). The stuff dislodges and falls away.
Boil it in water - it will dissolve.
And yes, the search times out for me every time I use it - you simply have to sit and be patient and when it times out, hit retry and the results will magically appear.
Dave
1980 TR7 DHC
1974 Jaguar XKE - Sold!
1994 Jaguar XJ12
[url="https://docs.google.com/leaf?id=0B26QZc97k0noYTAxMzUxZjgtMzZkZS00MWEwLWEyZmYtOWRkMzliNWZhMDA3&hl=en"]My Triumph Document Repository[/url]
Postby FI Spyder » 11 Dec 2010 17:18
Wow,,,you took your calipers apart. I prefer to replace the piston seals etc. without doing that. Not sure if there's a seal there but maybe someone who's taken them apart can say. I think the prevailing wisdom is not to split them, probably why there is no part listed if there is indeed a seal there.
Marko
Postby Marko » 11 Dec 2010 17:44
ive taken my apart , there is a rubber o ring in there , but the manual states that you shouldn't take them apart. Since there isn't any record of required torque to assemble them . I think any o ring that is higher than that hole will do, and that won't dissolve in brake oil. At least thats what i would do.
cozyheatdave
Postby cozyheatdave » 11 Dec 2010 19:20
Do we know for sure that it was a rubber seal and not a crushable copper washer like a banjo bolt?
I've been everywhere looking for an appropriate O-ring and not having much luck.
macmattom
Postby macmattom » 11 Dec 2010 19:34
<font face="Comic Sans MS"><font size="2"><font color="blue">Mine DEFINITELY had a rubber seal.
Apologies if the pictures are poor quality, but I zoomed in to get a closer look. Hope they help.</font id="blue"></font id="size2"></font id="Comic Sans MS">
Postby DNK » 11 Dec 2010 20:09
Did I miss something here. You took the struts off to do a brake job??[?]
"No More Cars For You"
71 TR6- Perpetual remodel
cozyheatdave
Postby cozyheatdave » 11 Dec 2010 23:33
Isn't that how it's done? [8D]
The car is being rebuilt from the ground up.... see under the V6 part of this forum..... My White TR7
Plus, you can get a glimpse of my engine, rear axle, and a few items in the thread near this one about how we heat our garages.
So, I've rebuilt the strut, actually awhile back, but now I'm in the mood for brakes.
Users browsing this forum: No registered users and 354 guests
