Seats
steve_1360
Seats
Postby steve_1360 » 28 Oct 2010 06:05
Does anybody know if you can convert a passenger seat to a drivers seat by swapping the adjuster over? Is it easy to do?
I do have a drivers seat to take the bits off.
Cheers Steve
Postby john » 28 Oct 2010 07:21
i think you'll find the Back rest is slightly twisted to aid getting in the car Steve.
But otherwise it should fit without any problems
Postby busheytrader » 28 Oct 2010 07:55
I did it.
It is possible to swap the seats over but the reclining lever will be nudging the transmission tunnel.
TR7 V8 DHC Jaguar Solent Blue. 9.35cr Range Rover V8, Holley 390cfm, JWR Dual Port, 214 Cam, Lumention, Tubular Manifolds, S/S Single Pipe Exh, 3.08 Rear, 200lb Spax & PolyBushes all round, Anti- Dive, Strut-Top Roller Bearings, Capri Vented Discs & Calipers, Braided Hoses, 4 Speed Rear Cylinders, Uprated Master Cylinder & Servo, AT 14" 5 Spokes or Maestro Turbo 15" Alloys, Cruise Lights, S/S Heater Pipes, Replacement Fuel Tank. No Door Stickers. Mine since July 1986, V8 from 1991
staningrimsby
Postby staningrimsby » 28 Oct 2010 08:28
What about the seat belt anchoring point, wouldn't that be on the wrong side as well [?][?][?]
1980 2.0 DHC (soon to be 16v) - Polly.
Postby nervousnewowner » 28 Oct 2010 08:52
be interesting to see how he did, [:D]
Postby busheytrader » 28 Oct 2010 18:20
Ok, this was some years ago.
IIRC, there are anchoring points on both sides of the seat for the belts so it's a simple swap over.
It passed several MOT's so no issues there.
There are others on the forum that have done this.
steve_1360
Postby steve_1360 » 29 Oct 2010 18:13
Thanks Guys
I shall try a straight swap first as the passenger seat doesn't get very much use
Postby tr8 » 29 Oct 2010 18:54
Easy to switch seat covers from right to left.
