Cruise Lights
The Old One
Cruise Lights
Postby The Old One » 17 Oct 2010 20:56
Which lights are the cruise lights wired into
Postby REPLIC8 » 17 Oct 2010 21:14
The red ones go at the rear & are wired to the rear side lights, the amber ones go at the front and are normally connected to the indicators.
Postby nervousnewowner » 17 Oct 2010 21:42
got my front ambers hooked up to the indicators but have welded up the holes for the rear ones.........[:p]
Postby bmcecosse » 17 Oct 2010 22:28
The fronts would normally also be connected to the side lights - so they shine at night when 'cruising'. They are not intended to be indicator repeaters - but can of course be used as such. They can also be connected to BOTH side and indicator circuits. At night - they will shine as intended with only a slight loss of brightness, and when the indicator is used at night - they will flash OFF as the indicator flashes ON - in other words opposite sense. In daytime - they will flash as normal - again slight loss of brilliance.
Postby busheytrader » 18 Oct 2010 08:05
A must for town driving, especially when pulling out at junctions at night. The recessed front side lights and indicators can be hidden otherwise.
TR7 V8 DHC Jaguar Solent Blue. 9.35cr Range Rover V8, Holley 390cfm, JWR Dual Port, 214 Cam, Lumention, Tubular Manifolds, S/S Single Pipe Exh, 3.08 Rear, 200lb Spax & PolyBushes all round, Anti- Dive, Strut-Top Roller Bearings, Capri Vented Discs & Calipers, Braided Hoses, 4 Speed Rear Cylinders, Uprated Master Cylinder & Servo, AT 14" 5 Spokes or Maestro Turbo 15" Alloys, Cruise Lights, S/S Heater Pipes, Replacement Fuel Tank. No Door Stickers. Mine since July 1986, V8 from 1991
Postby stevie_a » 18 Oct 2010 11:29
<font color="teal"><b>I agree with Roy
That they should be wired in to the side lights
I think it looks strange with only a red light at the back
As for wiring it in to the side lights and the indicators is that legal
To have them flashing at the opposite time to the main indicators. ?
</b></font id="teal">
Postby UKPhilTR7 » 18 Oct 2010 11:48
My rear ones are connected to my side lights and the front ones are connected to the indicators. I was thinking of changing the front ones so they are wired up to the side lights, but after thinking about it, I also think it is a must to have the indicators on the side of the car, so have decided not to change them around.
Postby Odd » 18 Oct 2010 13:33
OK, let's get these facts straight now:
The US side lights were wired together with the front and rear position indicators.
The oem side direction flashers (compulsory fitment in Italy and optional in other markets) looked like this,
and were wired together with the front direction flashers...
/Odd
Postby FI Spyder » 18 Oct 2010 15:39
Why would they have extra (round) side lights when they already had (access to) the side lights of the N/A cars that could be wired into flashers or just in on position as required by countries laws?
Postby Odd » 18 Oct 2010 17:58
Don't know - but that's the way they did it.
Not the first time British engineers made something bizarre
in the eyes of the rest of us. Probably not the last time either...
Jolyon39
Postby Jolyon39 » 18 Oct 2010 18:37
The 1981 front loom I have installed includes a spare connection that I imagine is for these lights. Do you know if tis is running lights (side lights) or indicators?
Jolyon
Postby Odd » 18 Oct 2010 21:39
Where is the connectors?
Up front - I'd guess side indicators...
Rear end of the bay - wing flashers.
Users browsing this forum: No registered users and 219 guests
