Electric Fan
The Old One
Electric Fan
Postby The Old One » 17 Oct 2010 18:58
I want to go the electric fan route
Can i just buy a second hand fan from a scrappie and
buy a thermostatic fan switch that i can fix into the
top of the radiator. If so does anyone know which switch
i should buy.
Thanks
kstrutt1
Postby kstrutt1 » 17 Oct 2010 20:58
I have a fiesta fan and switch on my V8, get on off an air con car as they are usually more powerfull.
The fiesta switch is M22 thread, I have added a adaptor in the top hose, I made mine on the lathe but you can buy them for around £20, you can also get bosses soldered into the radiator.
You also need to use a relay and as the starting current is high a seperate fused feed is ideal.
Postby john 215 » 17 Oct 2010 21:18
Just a word of warning, ensure the fan is wired to spin the correct direction and the blade are designed to spin the direction you want it to spin, suck or blow [:I][:0] If mounted in front or behind the radiator
Users browsing this forum: No registered users and 133 guests
