Fitting harder suspension bushes- How??
Dave Dyer
Postby Dave Dyer » 17 Oct 2010 18:57
An easy job I thought, I'll do the rear tie bars, I have a spare 1/2 hour this afternoon...How wrong I was, I've never tried doing anything as frustrating!!! It seems impossible and that was after an hour of trying!
I've coated the bush in rubber grease, got a large vice and tightened the vice to push in the bush, but it always starts to go in on one side at an angle then pops back out.
What am I doing wrong? there must be an easier way (I say hopingly) a knack of doing it right?
How did you fit yours?
Thanks, Dave
Postby Beans » 17 Oct 2010 19:22
Using grease will make the bushes slippery as you have found out by now [:p]
It is a rather straightforward job if you have a half decent vice.
Only thing to bear in mind when putting in the bushes (in particular the larger ones) is NOT to use any grease.
By using grease the bushes have a tendency to slip away in all directions.
Just make sure the inside off the arms are clean and smooth.
I only use grease on the last inside bit of the arm to make it easier for the bushes to "come out" at the back.
Postby REPLIC8 » 17 Oct 2010 19:27
I took mine to Robsports, as I was going there to buy some bits anyway. They removed the 8 old ones and fitted the new poly ones in less than an hour with no damage to my powder coated parts. All I had to do was sit in the office & drink a cup of tea!! Easy really. [:D]
Postby Odd » 17 Oct 2010 19:55
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Dave Dyer</i>
... there must be an easier way <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> Yes, there is:
Fit polyurethane bushes - they are split in two halves that go in from opposite sides.
With finger pressure only... [:)]
moestr7v8
Postby moestr7v8 » 18 Oct 2010 00:34
Hi Dave I have a pair of reconditioned tie bars powder coated and fitted with polybushes so they are already to fit.
I also have a set of trailing arms also powder coated and fitted with polybushes ready to fit.Polybushes supplied by S+S.
Email me if you are interested.
Moe
Postby FI Spyder » 18 Oct 2010 02:03
Yes, poly bushes are split. You just have to drill a tiny hole in them to allow the air in the centre to escape. I put a thin layer of clear synthetic grease on them.
Here the link to my bushing slide show:
http://s119.photobucket.com/albums/o131/Spit999/TR7/Pulling%20Bushings/?albumview=slideshow
When slide show starts click reverse order to get right sequence.
Postby busheytrader » 18 Oct 2010 07:57
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by REPLIC8</i>
I took mine to Robsports, as I was going there to buy some bits anyway. They removed the 8 old ones and fitted the new poly ones in less than an hour with no damage to my powder coated parts. All I had to do was sit in the office & drink a cup of tea!! Easy really. [:D]<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
They did the same for me with Front Spax Inserts on a weekday morning. I went up there with my struts, bought the Spax, and they kindly removed the old inserts and fitted the Spax in less than a minute each courtesy of a large vice and wrench. It all happened so quickly there was no fee, but also no tea.
TR7 V8 DHC Jaguar Solent Blue. 9.35cr Range Rover V8, Holley 390cfm, JWR Dual Port, 214 Cam, Lumention, Tubular Manifolds, S/S Single Pipe Exh, 3.08 Rear, 200lb Spax & PolyBushes all round, Anti- Dive, Strut-Top Roller Bearings, Capri Vented Discs & Calipers, Braided Hoses, 4 Speed Rear Cylinders, Uprated Master Cylinder & Servo, AT 14" 5 Spokes or Maestro Turbo 15" Alloys, Cruise Lights, S/S Heater Pipes, Replacement Fuel Tank. No Door Stickers. Mine since July 1986, V8 from 1991
Dave Dyer
Postby Dave Dyer » 19 Oct 2010 20:54
Thanks for your help guys,
Poly bushes sound like they would have been easier, but out of my budget though! Also Thanks for the offer Moe, again probably more than I could afford.
So I soldiered on with the harder more awkward rubber ones! I cleaned off the rubber grease as Beans recommended, which did help and stopped the bush moving out of place, but as I put force on the bush it tended to make it wider at the front, which in turn stopped it fitting! I came up with an idea to put a jubilee hose clip round the end to stop it expanding, but it didn't work.
I'm thinking along the lines of a piston ring compressor round the bush, but will try that another day, theres only so much you can take!!!
Cheers, Dave
Postby jclay (RIP 2018) » 19 Oct 2010 21:05
Get one of these. Fairly cheap and you will use it all the time.
Dave Dyer
Postby Dave Dyer » 19 Oct 2010 21:42
Hi Clay,
Thats a really great idea, I've never seen a press like that and like you say, it would be so usefull for loads of jobs, obviously for the bushes plus bearings, even ball joints. And it actually looks like its makeable as well, you've got me thinking now (my vigour is returning!)
Cheers, Dave
Postby Wayne S » 20 Oct 2010 08:47
That is fantastic! especially for ball joints!!
Users browsing this forum: No registered users and 268 guests
