Volt meter
pupinabox
Volt meter
Postby pupinabox » 27 Sep 2010 16:50
My conversion is beginning to come alive and I have a simple question.
My volt gauge is right around the 3/4 mark during the brief times I have had the engine running.
What does it mean when the volt gauge is on the high side or on the low side? Is mine in about the right spot?
[IMG=left]http://i160.photobucket.com/albums/t194/pupinabox/353.jpg[/IMG=left][IMG=right]http://i160.photobucket.com/albums/t194/pupinabox/tr7005.jpg?t=1271517043[/IMG=right]
prlee
Postby prlee » 27 Sep 2010 17:08
That sounds about right to me. Mine normally hovers around the 3/4 mark, the more electrics I have on it tends to dip. If under normal operating it is low this indicates either a battery or charging problem.
Pete
81 DHC (MOT and tax, nearly finished)
79 Spitfire (big hole found in floor)
Image ImageImage
Postby FI Spyder » 27 Sep 2010 18:20
Volt meter position can vary depending on a variety of causes but that's about the right area. Put a voltmeter across the battery and you should get between 13.5 and 14.5 volts when the engine is running a more accurate reading than the voltmeter.
Users browsing this forum: No registered users and 364 guests
