Gearbox Polybushes Post Fitment
Postby busheytrader » 27 Sep 2010 13:36
Has anyone picked up extra gearbox whine after changing their remote housing gearbox bushes to poly items, or replaced the gearbox mount?
It's only noticeable in 1st and 2nd and comes through the shortened S&S gearstick. The correct anti-rattle spring and plunger etc are all there. I've heard reports that overly hard rubber gearbox mounts could cause extra noise. Any item would have been harder than the slimy one I replaced at the same time.
TR7 V8 DHC Jaguar Solent Blue. 9.35cr Range Rover V8, Holley 390cfm, JWR Dual Port, 214 Cam, Lumention, Tubular Manifolds, S/S Single Pipe Exh, 3.08 Rear, 200lb Spax & PolyBushes all round, Anti- Dive, Strut-Top Roller Bearings, Capri Vented Discs & Calipers, Braided Hoses, 4 Speed Rear Cylinders, Uprated Master Cylinder & Servo, AT 14" 5 Spokes or Maestro Turbo 15" Alloys, Cruise Lights, S/S Heater Pipes, Replacement Fuel Tank. No Door Stickers. Mine since July 1986, V8 from 1991
Postby Hasbeen » 02 Oct 2010 09:33
Adam I hate to see someone get no answer, so NO.
Postby FI Spyder » 02 Oct 2010 16:44
I changed my rear transmission mount (as well as all the front bushings with hard poly) and I had a whine from the differential. I topped up the diff (not much) and that seemed to quiet it a bit. Last winter I did the rear with a combo of hard and soft poly when I had the gas tank out. There is a different whine from the differential. Now it could be thought to be a transmission whine but I'm pretty sure it's the diff. Since the front was done in winter of 06/07 and previous to that I just drove it back from Sacramento I can't really recall if it had a whine before or not so I don't know if it (mount) transmitted the whine or if it was there all along.
Sorry, not much help.
moestr7v8
Postby moestr7v8 » 02 Oct 2010 23:43
Hi Adam
My gearbox bushes were replaced with poly bushes last year when I had the clutch replaced and new fulcrum pin fitted, but there is no whine at all that I can detect.
Moe
Postby jclay (RIP 2018) » 03 Oct 2010 01:24
Because everything is tighter now, sound could be amplified. Before there saw slop in the system that could have deadened the vibration of the different parts.
Postby busheytrader » 04 Oct 2010 19:39
Thanks for the info guys. I think it might be due to an overly hard gearbox rubber mount so will give it a while longer.
Users browsing this forum: No registered users and 83 guests
