Hmmmmmm!
nadg63
Hmmmmmm!
Postby nadg63 » 04 Sep 2010 23:44
Whilst pulling the engine out of our car, this was parked there, obviously someone likes it .................... !? [xx(]
Postby Hasbeen » 05 Sep 2010 00:16
If they had put the things in the front panel, something like the nostrils on that Darwin car, it should aid cooling.
To my mind, where they are, any airflow would only increase the pressure in the engine bay, reducing the air flow through the radiator. It's hard enough to get rid of the air coming through the radiator as it is.
Still it looks like a car that has had much love & attention lavished on it.
At one stage I almost fitted vents to the inner fender to try to give the 8s engine bay hot air another way out.
In the end I didn't do it, as I was worried there just may be a high pressure area in the front wheel arch, & I would just make things worse.
Don't you hate it when you know, you just don't know enough, to know what you are doing.
nadg63
Postby nadg63 » 05 Sep 2010 03:34
I'm not 100% sure these are even vented into the engine bay, strongly believe they are blanked off!?
trv8
Postby trv8 » 05 Sep 2010 04:04
Nope. Not for me [V].
Postby nervousnewowner » 05 Sep 2010 07:54
wouldnt they be there for air induction into the carb or carbs more than for cooling. on big gassers usually they are induction more than extracion......[:)]
nadg63
Postby nadg63 » 05 Sep 2010 08:34
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by nervousnewowner</i>
Will have a closer look next time I see it! All I do know is it's a 3.5 with a Holley on it running an <i>auto </i> box.
RadioGuy
Postby RadioGuy » 05 Sep 2010 08:38
I would tend to agree with Nervous.
I would also like to see a picture from 20 ft or so to get the whole effect.[:p]
Nice Job though!
Postby Cobber » 05 Sep 2010 09:06
They've chopped the vents and power bulge from the bonnet of an XB or XC Ford Falcon GT, GS or GXL and incorporated it into the bonnet of the TR
85'Alfa 90, 69'Ford F250.
Postby nervousnewowner » 05 Sep 2010 12:30
single holley, yeah it for induction not cooling, still prefer a shaker hood tho,....[:D]
V8Wedgehead
Postby V8Wedgehead » 05 Sep 2010 14:20
Paint it black and you will have one of the last of the V8 interceptors!
Michael
Postby tr8 » 05 Sep 2010 14:48
Here is one of the best designed one that I have seen.
Postby PeterTR7V8 » 05 Sep 2010 21:10
They are for induction but I think (correct me if I'm wrong) that Hasbeen was referring to the interferance of the air rushing in to the top of the engine bay with the air rushing in from the front causing bad air flow through the radiator. If the top intake was sealed so it all went into the carb it would be OK which is why you see race prepped cars with a big bath around the carb intake.
Postby Hasbeen » 06 Sep 2010 00:28
I see it all now Peter.
I thought it was too far back to be supplying cold air to the carb, but with that air dam, it all makes sense.
Users browsing this forum: No registered users and 287 guests
