Track Day in a DHC......
Postby busheytrader » 27 Aug 2010 13:26
Has anyone taken a track day in their DHC?
Apart from a crash helmet was there any special preparation needed like a roll bar, advisable I know, but do they allow you on the track without one?
Postby Beans » 27 Aug 2010 16:18
Yes, but most important is to uprate your brakes!
Postby john » 27 Aug 2010 16:55
certanly not
in fact heres me in mine.
take it at your own pace and build up with each lap but don't go at it like a bull at a gate
http://www.youtube.com/watch?v=mYJDVVXtK_0
Postby PeterTR7V8 » 27 Aug 2010 20:50
It depends on the event rules & your own sense of self-preservation but here you would need a roll cage with a modified car.
Standard brake pads will need a rest after every few laps & you will need to be aware of oil surge with the RV8. Watch for the oil light when you get on the power out of a corner. If it is an issue overfill the sump to 1/2 inch over the high mark. If you have a breather/catch tank system keep an eye on the tank. The Rover likes to accumulate oil at the top & if it starts to pump actual oil into the breather line the catch tank will fill up in a couple of laps.
So, come in after 2 laps & check everything before & approach your limits from the safe side. Have fun & don't turn in to the corners too early!
Postby john » 28 Aug 2010 17:27
hmmm i think most track days are a bit tamer over here i've done a couple now and as i said there can be anything from an mg midget to an old alfa to an aston martin
i doubt you will be turning your tyres to molten rubber or your brakes for that matter
Users browsing this forum: No registered users and 345 guests
