Front strut cartridge
pupinabox
Postby pupinabox » 21 Aug 2010 19:20
I am trying to remove the front strut from the tube. Any ideas on how to remove this "nut", if that is what it is. Keeping in mind I don't have a huge selection of tools i.e. air tools.
[IMG=left]http://i160.photobucket.com/albums/t194/pupinabox/353.jpg[/IMG=left][IMG=right]http://i160.photobucket.com/albums/t194/pupinabox/tr7005.jpg?t=1271517043[/IMG=right]
V8Wedgehead
Postby V8Wedgehead » 21 Aug 2010 19:23
I use a vice and large channel lock pliers or pipe wrench. Once it breaks loose your good.
Michael
Postby bmcecosse » 21 Aug 2010 19:53
If need be - carefully apply a little localised heat around the neck of the tube.
Postby saabfast » 21 Aug 2010 21:14
If it is original there may be a locking 'dimple' punched in the tube to lock the nut. This needs to be drilled out to release the nut.
Saab 9000 2.3 FPT Auto
Postby bmcecosse » 21 Aug 2010 21:27
Ahhh - yes! I forgot about the dimple!
V8Wedgehead
Postby V8Wedgehead » 21 Aug 2010 23:56
The dimple must be a UK & europe thing. I have never seen that state side.
Michael
Postby Hasbeen » 22 Aug 2010 00:27
The first mention of this dimple was in a post by jclay, I think.
I can't imagine it would have had anything to do with Triumph, they would have just ordered struts to drawing, & the manufacturer would have "dimpled" them as they thought necessary.
Postby FI Spyder » 22 Aug 2010 06:27
The dimple was to lock in the nut. My California spider had it. I didn't know about it at the time and just wrenched it off with a monkey wrench and extension pipe for leaverage.
Postby Beans » 22 Aug 2010 09:01
Never seen anything remotely like a dimple on the struts top.
I had a few issues though with aftermarket strut inserts (which were slightly wider).
They didn't properly fit due to the struts tube being deformed slightly where the bracket for the brake hose was welded on.
If the lock nut doesn't move, that's because it is rusted solid to the strut.
So you'll need penetrating oil and patience, or heat.
But the last option will ruin the insert.
Postby bmcecosse » 22 Aug 2010 10:56
Not if it's just a little local heat - Chef's flambé gas torch is ideal........ Just don't let the 'chef' catch you using it!
pupinabox
Postby pupinabox » 22 Aug 2010 16:56
Looked it over and did not find a "dimple".
The solution: Go to the tool store and find a $15 Mother-of-all wrench and it popped right off with some help from Mr. PB Blaster. Yeah.
Postby Workshop Help » 22 Aug 2010 18:28
Perhaps, my friend, you may want to clean your spectacles. I see the dimple as clear as day in your second photo thru my spectacles.
pupinabox
Postby pupinabox » 23 Aug 2010 01:30
After proper spectacle application I see said "dimple". If that is what is supposed to hold the nut in place, the dimple maker must have been asleep at the switch cause that little "dimp" ain't holding anything.
But EUREKA, success!!
gingerstu
Postby gingerstu » 26 Aug 2010 12:10
Glad to see it's all done.
I am just picking up where I left off with my '7 from 18 months ago (having a house extension built & temporary loss of garage scuppered progress) and am in the process of sorting out the front suspension.
When refitting the strut, should some sort of sealer be used on the top face of the stut top so that it seals against the inner wing ?
and if so, should this sealer be seam sealer, or silicone sealer ??!
cheers
Stu
pupinabox
Postby pupinabox » 27 Aug 2010 01:44
I don't think so, at least the manual I am using does not mention anything like that.
I am now having another bit of problems, though. Got the struts in the tower, the lower links in place, the steering bits bolted on along with the calipers, BUT NOW THE SWAY BAR THAT I TOOK OUT AT THE BEGINNING OF THIS SEEMS TO BE ABOUT AN INCH OR SO TO WIDE TO FIT BACK IN THE HOLES OF THE LOWER LINKS[V] ANY IDEAS?
Users browsing this forum: No registered users and 293 guests
