Wiring connector
Jim_Blackwood
Wiring connector
Postby Jim_Blackwood » 12 Aug 2010 02:26
Where can I get connector bodies for the wiring harness? Specifically, the main one for the engine harness where it goes through the firewall and plugs into the dashboard harness under the glove box. This is a 1980 TR7 and it is a 7 pin connector, 2 rows of 3 and the last one on top like an arrow head. The connector body is broken and it won't hold the contacts in place long enough to make contact.
Jim
catmanboo
Postby catmanboo » 12 Aug 2010 02:46
the connector pins(male/female) theoretically should have a tight enough fit to each other to stay put. the plug bodies with their interlocking shells just provide fail-safe & secure mating. you may need to tighten up the female lugs (alright, shaddup, you guys![:p]) by squeezing them carefully to close up slightly. the pins can usually be extracted by depressing the tiny barb on the connector that retains it in the shell. you'll need a TINY probe to do this. I've had to do this a number of times over the years on various vehicles & other equipment to either tighten a connector, or for a re-wire. it's a pain in the ass, but beats crimp-lug or wire-nut butchery[:D]
Postby Cobber » 12 Aug 2010 06:03
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by catmanboo</i>
<font size="2"><font face="Comic Sans MS">I wouldn't 've said anything......honest! </font id="Comic Sans MS"></font id="size2"> [:D]
85'Alfa 90, 69'Ford F250.
Jim_Blackwood
Postby Jim_Blackwood » 12 Aug 2010 21:11
Thanks.
JB
Users browsing this forum: No registered users and 40 guests
