Electrical HELP!
TriumphCMT
Electrical HELP!
Postby TriumphCMT » 21 Jul 2010 03:12
The white wire that comes off the ignition switch powers the dash and the coil. I've have disconnected the ignition switch completely and for some reason the white wire still has power.
There must be a short somewhere between the white wire and a purple or brown wire.
Without having to open up the entire wiring harness, how can I find the short??????
- Chris
Postby bmcecosse » 21 Jul 2010 09:32
Is everything switched off ?
TriumphCMT
Postby TriumphCMT » 22 Jul 2010 00:05
Well the ignition is disconnected and all the lights and dash switches are off.
- Chris
Postby jclay (RIP 2018) » 22 Jul 2010 02:05
The white wire goes to a whole gambit of things. The instrument cluster, A/C blowers, fuel warning light delay unit, windshield wiper motor.
It also ties into a green wire through a fuse that powers the horn and a bunch of other things. It also goes to the coil. The relay that powers the A/C fans is always hot. You might start there. Pull the relays one at a time and see if you lose power to the white wire.
Do you have a wiring diagram? You can down load the ROM from my download site. TR7man.pdf
What problem are you having with your car? You are just 4-5 hours away.
TriumphCMT
Postby TriumphCMT » 22 Jul 2010 19:44
WOW that helps ALOT!!! i'm going to start checking that right away! Thanks jclay!
- Chris
Rblackadar
Postby Rblackadar » 23 Jul 2010 23:14
Jclay = Master of Documents .... I have to say I enjoy the body work guide I downloaded from you Jclay.....I swear I bring that booklet out on every lunch break at work...by now I should know how many welds and what kind go where....Thanks again!
Postby jclay (RIP 2018) » 24 Jul 2010 03:37
Thanks, Rblackadar!
Great to hear from you again. I am just the steward of the documents. They are there for every TR7/TR8 owner to use. I remember a web site years ago about a guy building a 2+2 TR7. He was documenting every step. Then it just disappeared. Maybe we can keep all this information for the next generation of TR7/8 owners.
TriumphCMT
Postby TriumphCMT » 24 Jul 2010 03:49
Well jclay, you were right. It was a relay problem. All my problems where coming from the starter relay!!!! I mixed the relays and put a different relay on the starter so the car would start but would keep the white wire hot!
All this nonsense from a stupid relay mistake!![xx(][xx(][xx(][xx(]
Hope this helps people in the future!
- Chris
