argghh crap
birminghamtr7
argghh crap
Postby birminghamtr7 » 13 Jun 2010 09:40
a bird s**t on my car yesterday didn't spot it till this morning wipe off with damp cloth, left a mark, then ferecla, still marked, then hand glaze, then polish but i can still see a mark where it lay. any ideas [:(]
Postby Underdog » 13 Jun 2010 10:20
Only thing I could sugest is a light sanding with 1500 and buffing. Does it have clear coat? That stuff is nasty. Must be the acid in it.
Jim Underwood
Postby FI Spyder » 13 Jun 2010 15:58
Is the paint original? If so the TPA paint isn't very chemical resistant. I would take a power buffer and some polishing compund (I use Turtle Wax stuff) and try and polish it out. I had some stains from Metalready when I was using it on battery tray and it got on fender (wing). Took it out but be careful. The paint on my passenger door was worn down to primer on the swage line from polishing by PO.
John Wood
Postby John Wood » 13 Jun 2010 20:04
God knows what the birds eat by me but their shit is like acid. My Black Audi has at least 6 marks that have completely ruined the paint, one bird attack on the bonnet even pitted the paint because it was on for a few days.
My last Black Vectra however was untouchable. Must have been stronger paint.
1975 FHC
KDU483N
Postby gaz » 13 Jun 2010 20:58
use something quite aggressive but not "T" cut orribble stuff
something like autoglym's paint renovater followed by autoglym's super resin polish or if its not so bad just use the super resin either way it will takesome elbow grease, but make sure you use a wax afterwards
if all else fails then as said before wet "n" dry and buff
good luck.........
Steve-LPS-Thomas
Postby Steve-LPS-Thomas » 13 Jun 2010 21:38
Raspberries.. we have a soft fruit area and they like the raspberries!
<hr noshade size="1">
Bobbieslandy
Postby Bobbieslandy » 13 Jun 2010 21:39
I've got an air rifle you can borrow[}:)]
Postby Cobber » 14 Jun 2010 07:41
<font face="Comic Sans MS"><font size="2">I had a bloody government duck ( cormorant )back one out on a boat I had, the result ate into the fibreglass gelcoat! It needed serious repair I dunno what it had been eating but it cant've been good! [:0] </font id="size2"></font id="Comic Sans MS">
85'Alfa 90, 69'Ford F250.
Postby John Clancy » 14 Jun 2010 08:22
It's always acidic and if it's not removed quickly will very often scar the paintwork. I had a slug crawl up on the car and die a few years back. This permanently damaged the paint where it finished up but a serious cut back with rubbing compound, then T-Cut followed by plenty of Autoglym polish with a lot of elbow grease made it practically invisible.
Postby TR Tony » 14 Jun 2010 10:13
Try 3M Fine Compound to remove the mark then Imperial Hand Glaze to finish. I have found this to work very well on small marks as long as the paint is in good condition.
Postby PeterTR7V8 » 14 Jun 2010 12:01
Exercise a bit of caution before using any cutting compounds. Your paint is surprisingly delicate. Test on an old car first.
Postby gaz » 14 Jun 2010 14:56
is the TR7 not old enough Peter[;)]
RadioGuy
Postby RadioGuy » 14 Jun 2010 15:37
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by gaz</i>
That was good ! ROFLMAO[:D]
Postby PeterTR7V8 » 14 Jun 2010 20:59
I'll just keep feeding you the lines...[:D]
