SPST contact configuration
Postby UKPhilTR7 » 30 May 2010 21:38
I have a Snap-in Illuminated Miniature Round Rocker Switch from Maplin, that has a SPST contact configuration. I was wondering if anyone has one and knows which pins are which are on the back.
Postby Beans » 30 May 2010 21:44
Don't even know what SPST means [:I]
Postby UKPhilTR7 » 30 May 2010 21:48
Lol snap and I am trying t wire it in
http://www.maplin.co.uk/Module.aspx?ModuleNo=44877
Postby saabfast » 30 May 2010 21:57
SPST = Single pole, single throw. Basically a one way in and out switch. If it is illuminated it will also normally have an earth for the switch illumination. It is easiest to test with a meter to see which terminal is which. However, I have a Maplin illuminated switch on the override for the rad fan which I have never been able to work out! The warning light seems to be permanently on or not working. I didn't worry as I have a warning light on the circuit to show if the fan is running anyway.
Saab 9000 2.3 FPT Auto
Postby UKPhilTR7 » 30 May 2010 22:14
Funny enough Alan that is what I have got mine for too and tryin to set up.
Postby jclay (RIP 2018) » 31 May 2010 01:36
Main Neon lamps require AC current, not DC current. Also they require move than 12 volts.
Postby saabfast » 31 May 2010 09:19
Quite right Clay, I didn't read the link. However, mine is definately 12V LED and still dosen't do what it said on the tin ('LED illuminates when the switch is on').
Users browsing this forum: No registered users and 248 guests
