Replacing points
Postby Beans » 12 May 2010 20:29
Welcome to the Wonderful World of Wedges [:D]
As for removing the points;
Remove the two springs carefully and remove the two retarding weights.
This will give you slightly more room.
If necessary turn the engine to give better access to the points.
Postby saabfast » 12 May 2010 20:41
It can be done without removing the springs etc. From memory, after removing the rotor arm use a longish magnetic screwdriver and remove the large cheesehead bolt in the middle of the points (don't drop it). Pull the spade connectors out from behind the spring (where it seats against the plastic square on the side)and lift off the points. Replacing is the reverse but a bit trickier due to the space restriction. Adjusting is another challenge, trying to see when the heel of the points are on the cam and getting a very small feeler gauge in to check the gap. Some prefer to remove the dizzy, but that (and replacing it) is a challenge in itself.
Saab 9000 2.3 FPT Auto
Postby TR Tony » 12 May 2010 21:12
If you go to the trouble of removing the dizzy, buy a Lumenition kit & save yourself the grief of having to change the points in future.
TR8 FHC EFI Factory development car Inca Yellow</font id="size1">
Users browsing this forum: No registered users and 197 guests
