Extra rubber on strut spring seat?
prlee
Postby prlee » 10 May 2010 19:11
Dismantled the front suspension this weekend. I will be fitting poly bushes to the suspension and subframe and uprated springs.
When I took the strut apart I found a heavy duty piece of rubber sheet about 1cm thick unde the lower rubber seat, seems non standard, any ideas why and should I put it back when I fit the new springs?
Pete
81 DHC (Undergoing minor body repair)
79 Spitfire (Current Main drive)
Image Image Image
Postby Wayne S » 10 May 2010 20:27
If thet were lowered springs it was probably there to stop the springs clonking up and down. Poly seats are thick enough though to do the job.
