Misfire
Monkeyzak
Re: Misfire
Postby Monkeyzak » 22 May 2017 07:24
I have nothing but gut feeling to base this on but I think it might be my electronic ignition too.
I'll order all the other bits today. Plug, leads etc. Presumably replacing the electronic ignition will be considerably more expensive
Do you buy a whole electronic ignition system or replace bits?
John_C
Re: Misfire
Postby John_C » 22 May 2017 10:29
If you have the ability the cheapeast option is to put the car back to points and condenser. Then after it's set up properly if it still has the same misfire symptoms you won't have wasted too much on a replacement electronic ignition. However, the unit I'm currently running in my car is only about £40 to £50 and is completely hidden inside the distributor. If it carries on working for the next 20 years I may even grow to trust it!
www.triumphdvd.co.uk
Monkeyzak
Re: Misfire
Postby Monkeyzak » 25 May 2017 17:55
Replaced most of the ignition parts today. Took the car for a spin. No misfiring. So hopefully we're done!!! There is a new problem but I'll start a new post. Thanks as always for the help
