Aviation Gasket Sealant
Re: Aviation Gasket Sealant
Postby UKPhilTR7 » 28 Nov 2020 20:21
To tell you the truth Has been I have not had the pump off yet to check it. I was thinking of taking it off and having a look but not checked for cracks or the diaphragm. I must admit that I still ling the idea of the electric upgrade and too true Beans, the extra wire would be a good winter project. I have been looking all around but I must admit that this one is catching my eye:
https://www.ebay.co.uk/itm/Classic-Kit-Car-12v-Aeroline-Electronic-Fuel-Pump-Pressure-Regulator-Filter/202685295613?hash=item2f30fc2bfd:g:8CkAAOSwn4ZcQEBe
Postby Beans » 28 Nov 2020 21:50
You'll need a good quality pressure regulator with these. Don't ask me why I know :P
And a good size filter between pump and tank won't harm either.
But better follow Russ' advice in your other thread. This choice is overkill for a standard engine.
And it looks like a cheap copy of the original Facet pumps.
dmtrmp6
Postby dmtrmp6 » 28 Nov 2020 23:54
Phil,
Concur Theo's latest advice (overkill). See comments on your other 'fuel pump' post. Rgds, DM
supercass
Postby supercass » 25 Dec 2020 12:53
Is the aviation gasket sealant ethanol proof? supercass
Postby Cobber » 26 Dec 2020 02:12
Here's the link for the technical data sheet: https://www.permatex.com/wp-content/uploads/tech_docs/tds/80019.pdf
I gather that you're concern is with the fuel/ethanol blends.
I doubt that the smaller percentages of say 10% used in the typical blend won't have any appreciable effect on the gasket sealant but I would be wary of using it on high percentage mixes or straight ethanol.
'80 Triumph TR7.
'98 MG-F.
'83 Jaguar XJ6 Sovereign S3.
