Boot / Trunk Lining - Triumph TR7 / TR8
hwadd
Triumph TR7 Boot lining
Postby hwadd » 08 Sep 2019 12:36
UK Phil where did you get those led backlights 5 ur tr7?!!
HUGH
Re: Triumph TR7 Boot lining
Postby UKPhilTR7 » 15 Sep 2019 20:29
Hi Hugh, I got all my bulbs of ebay. If you have a search for Dash LED's, you will be able to see the chart that I put together to show which ones are needed.
hwadd
Postby hwadd » 31 Mar 2020 19:54
Richard,
How did you get your boot carpet looking so good?!! I’ve purchased a deluxe boot carpet from “hopping crossing” Nr Melbourne Australia and it looks ok!! But definitely not as good as yours!!
HUGH
Postby Cobber » 01 Apr 2020 02:02
hwadd wrote:Richard,
HUGH
That's "Hoppers Crossing" and no, I've got no idea as to the origin of that name
'80 Triumph TR7.
'98 MG-F.
'83 Jaguar XJ6 Sovereign S3.
Rich K
Postby Rich K » 01 Apr 2020 15:38
Hugh,
If you use automotive carpet it has a certain amount of give so that you can stretch and fit it over curved sections like the wheel arches without it rucking up. Also you need to use a heavy duty adhesive which you should be able to get from the same suppliers as the carpet.
Rich.
Ford Ranger Wildtrak
Jaguar XKR Supercharged
Postby UKPhilTR7 » 10 Apr 2020 11:12
It sure does have a certain amount of give in it, the automotive carpet. However, unfortunately if does not have enough to cover the rear deck panel.
supercass
Postby supercass » 10 Apr 2020 16:08
Four way stretch carpet, the type often used in vans should do.
supercass
Users browsing this forum: No registered users and 16 guests
