Back axle rebuild
jeffremj
Re: Back axle rebuild
Postby jeffremj » 23 Nov 2016 20:47
Bobbieslandy wrote:I thought scullery was something entirely different and illegal in most states.
A bit of skullduggery perhaps?
Bobbieslandy
Postby Bobbieslandy » 23 Nov 2016 23:07
:wink: I've got my axle back at last and since found the diff carrier shims are unobtainium. Bugger. So, i have one original diff shim and the original pinion shim, that's it. Can the thickness of the diff shim i have lost be calculated from the gap? Ie assemble it with a shim on one side, machine a piece of steel to slip in the gap left by the missing shim to ensure the diff is right over to one side but leave enough room for a feeler guage. Talk about making an absolute balls up of this... How did they calculate the size of the shims from the factory? I can't imagine for one second they had a guy spend a whole week on one axle! Then again maybe they did if you factor in strike action and tea breaks... thanks guys.
Steve @ SandS
Postby Steve @ SandS » 24 Nov 2016 09:12
Bobbieslandy wrote::wink: I've got my axle back at last and since found the diff carrier shims are unobtainium. Bugger. So, i have one original diff shim and the original pinion shim, that's it. Can the thickness of the diff shim i have lost be calculated from the gap? Ie assemble it with a shim on one side, machine a piece of steel to slip in the gap left by the missing shim to ensure the diff is right over to one side but leave enough room for a feeler guage. Talk about making an absolute balls up of this... How did they calculate the size of the shims from the factory? I can't imagine for one second they had a guy spend a whole week on one axle! Then again maybe they did if you factor in strike action and tea breaks... thanks guys.
I have a large selection of the shims
Steve @ S&S Preparations
www.ss-preparations.co.uk
Bobbieslandy
Postby Bobbieslandy » 24 Nov 2016 19:10
That's a huge relief, thanks for letting me know Steve. Just got to work out what size i need now. I was up your way not that long ago, Lloyd colne BMW's spraybooth extract fan parted company from the motor, I happily sorted that for them but refused to clear up the brown stain left by the painter when the fan blew up :-)
sydney.wedgehead
Postby sydney.wedgehead » 26 Nov 2016 02:52
pls excuse the sideline commentary...
Rob, if getting this toy on the road is the priority it may be better to palm the axle rebuild off to S+S so you can focus on prepping the rest of the car.
Can't wait to read your reports and see pictures of you using it for the intended purpose!
Users browsing this forum: No registered users and 14 guests
