Xmas cards repost.
Postby stevie_a » 25 Dec 2013 11:07
<font color="teal"><b>So sorry to hear this Andrew
I know it has happened a the worst possible time but it will all be ok in the end.
I work in the flood restoration company and by the end of it you will be sitting in a lovely newly decorated house.
If you want any advice I am only a e-mail away.</b></font id="teal">
Postby Cobber » 25 Dec 2013 11:13
That's an indoor swing pool in real-estate agents speak!
Seriously that's a bummer, I had a washing machine go nuts in the middle if the night and decide to flood out the house, that was bad enough with nice clean water, I can only imagine how much worse it is with that stuff!
'98 MG-F, 69'Ford F250.
Postby Maxwell » 26 Dec 2013 18:37
An Update for those interested: the water has now gone from inside our house and Mazda has been moved to high ground, but the house is currently uninhabitable - cold, dank, smelly and full of silt. The next weather pattern scheduled to hit Kent on Friday\Saturday, then perhaps we can get the de-humidifiers in and the heating checked.
Maxwell [;)]
2.0 TR7 FHC \ Current
1.8 Mazda MX5 \ Current
Postby Chris Turner » 26 Dec 2013 19:21
Andrew, Hope everything goes according to plan and you can move back soon.
www.triumphtrs.co.uk
THE Coca Cola car
TR7 Sprint SJW 539S
Postby Maxwell » 26 Dec 2013 22:44
Hi Chris. The plan is there is no plan. Guess it could be six/nine months.... Just depends on what the loss-adjuster/surveyor finds. The good news is we saved 90% of our contents, but the upstairs looks like a furniture depository.
Hey-Ho! The season of goodwill to all men! Andrew [:)]
Postby silverseven » 27 Dec 2013 23:20
good to hear damage wasn't too excessive.... hope your insurance won't put up too much of a fight!
Postby FI Spyder » 28 Dec 2013 14:01
Holmes on Home Inspection did a TV spot when they did a Holmes house reno at the High River floods. Most contractors did a strip and reno just after the water went down. He had the dehumidifiers going for weeks until the wood and cement foundation moisture content went down to acceptable levels other wise mold will grow from the residual moisture. He also used "pink wood" which is treated for moisture, mold, insect resistance (it's only a little more).
If you google: holmes high river video
you can go to HGTV video. You have to wait through two ads to get to it (nothings for free). It's well worth watching. Can't direct post link as it's too long. It's a must watch for any one with flood damage.
Postby Maxwell » 28 Dec 2013 16:10
Thanks for all the advice - we've have been here before in 2002.
One internal door looks to have expanded a bit, but others seem OK. Kitchen Units also seem OK at the moment [with no obvious signs of water-blown carcass] but will need removing [and reinstalling] to get to the walls behind.
Still de-humidifying, hope to introduce some heat to the property on Monday. Anti-mould and anti-bacterial solution already used on floors and up the walls to just beyond the flood-line.
Postby FI Spyder » 28 Dec 2013 18:24
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Maxwell</i>
It's the dampness in behind the walls you have to worry about, both in the insulation (unless you use polyurethane foam) and the wall studs. Good luck with it. Don't rush the drying process.
Postby Hasbeen » 28 Dec 2013 21:02
Pity you can't move it over here for a while.
34C yesterday, with only 32% humidity, & a 10 knot breeze. Bound for 38C today, with similar humidity.
That would dry you out quick time, just by opening the doors.
Have you had your insurance assessment yet?
Postby Maxwell » 29 Dec 2013 08:29
If only I could move! Do you accept Wrinklies with less than £1,000,000,000 in the bank?
The Loss-Adjuster will be coming on Tuesday.
Andrew [;)]
Users browsing this forum: No registered users and 105 guests
