Footwell vents
trickyx12000
Postby trickyx12000 » 13 Nov 2012 23:10
lol.. yeah my spider is currently on( i hope) the indian ocean,
10,000 miles in two months and i havent had to put a drop of gas in! <blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Image
kstrutt1
Postby kstrutt1 » 14 Nov 2012 19:14
Is there any other ducting in front of the wheelarch etc or does the air flow naturally?
I am thinking they cold make the footwells in my v8 cooler in the summer.
rgsSpider
Postby rgsSpider » 14 Nov 2012 21:21
The project begins! I got the set of vents on eBay, they are on their way and should be here Friday. Ordered a new set of vinyl footwell covers with the holes already in them from VB. The panels look great and seem to be well made. I laid the old panels on top and traced the door opening edge onto the new ones, they provided ample extra length of material for this. After removing the original panels there were blanking plates riveted in place. I just drilled out the rivets and removed the panels. So now I'm waiting with tools in hand for the UPS guy!
Randy
mrpatatomoto
Postby mrpatatomoto » 15 Nov 2012 00:17
My FHC came with AC so I never knew these even existed, Living in Southern California I'm not sure I would ever close them. We took the AC unit out when we got it since it wouldn't come on and I didn't think it necessary. but a breeze from the foot wells would make it a whole lot more comfortable. Does anyone know if they are available stateside anywhere the only set on Fleabay right now look fairly rusty.
~Mike
1975 TR7 FHC ACL5526UC
Postby Odd » 15 Nov 2012 04:53
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> Is there any other ducting in front of the wheelarch etc or does the air flow naturally? <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> There's no ducting needed. It's a healthy high pressure in there - due to car movement alone.
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> Does anyone know if they are available stateside anywhere <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> Call Ted Schumacher in Ohio - he's the one who make the modern version...
Spectatohead
Postby Spectatohead » 15 Nov 2012 05:11
It would be nice if the air flowed when you were stuck in traffic on a 90 degree day. Once you start moving it makes a huge difference, especially if you are wearing sandals. [;)]
Jim Clark
'80 TR8
'97 Maxima 5spd
mrpatatomoto
Postby mrpatatomoto » 15 Nov 2012 06:33
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Spectatohead</i>
You could rig up some 12 volt computer fans, that would keep it flowing, count even run it through a switch so it doesn't run when its not needed.
~Mike
Postby john 215 » 15 Nov 2012 07:23
Got my trim's from the gents at S & S Prep, cheer's Steve [8D]
Orignal spec trims made in Feb 80
Now need to remove blue leather trim from the 'spare trims ' and replace the tan PVC
1976 Speke FHC Beauty
kstrutt1
Postby kstrutt1 » 16 Nov 2012 17:27
http://www.cbsonline.co.uk/mobile/produ ... are_VENT11
I thought I might just mount a pair of the above in the existing blanking plates, any thoughts?
Kevin
Ianftr8
Postby Ianftr8 » 17 Nov 2012 08:26
Looking good - looks like we have started a trend.
Dont forget that the extra vinyl should wrap round the A post under the door seal to hold it into place.
Ian
Ian Freeman
1979 TR8 DHC
Triumph Courier
Triumph owner for 31 years
trekcarbonboy
Postby trekcarbonboy » 17 Nov 2012 13:11
Bit of a chill while driving to work this morning. 29f and the vents where open. Easy enough to close the drivers side while driving but not so easy for the other side. Brrrrrr [:I]
Craig '75 2.0 FHC
Postby FI Spyder » 17 Nov 2012 13:55
Took the car to the club meeting Thursday night as it's been dry (100+ Km round trip) with temp's just below double digits C. It was surprising that the cabin didn't warm up with just the motion of the car through the air, heater on full. I had to turn on the fan and have it run on low. Coming back (9:30pm) I went through a fog patch that froze on the windscreen and had to move the lever from car to screen. Glad I didn't have any foot well doors to add any drafts.
Postby john 215 » 17 Nov 2012 17:48
Hi
There WAS a set of vents that ended on ' The Bay ' today and as up here at the NEC and talking to a gent about my car and the club missed the end by seconds [:(][:(][:(] Oh well will keep looking !!
rgsSpider
Postby rgsSpider » 17 Nov 2012 20:59
Well I knew it was too good to be true! I'm not real happy with these new vents. The holes do not match up with the ones the blanks were riveted to. I know I can drill new ones, but I really don't want to end up with a lot of holes in the outside wall like that. Plus, the holes are close, but not close enough, and drilling new holes may be too close to the existing ones, blowing out everything. Also, when I test fitted everything, the latches that hold the vents closed come outside the hole in the trim panel and clamp down onto the trim panel. I'm just not loving the way that looks. I'm thinking I'll be putting these back up on Ebay and keeping an eye out for some originals.
Anyone interested in these?!
Randy
Postby john 215 » 18 Nov 2012 05:33
Hi Randy,
Sorry to hear your problems, seems so common on remanufactured parts not fitting , not that the original stuff was that good !!!
If you relist then do so with UK postage costs !!
Users browsing this forum: No registered users and 296 guests
