coleford transport carnival
zoe
Postby zoe » 22 Apr 2011 18:46
ok !! Dave, mite come , but u will have to keep me away from any Jensens there or i may be arrested !!!
Postby nervousnewowner » 24 Apr 2011 14:06
yeah think we can manage that zoe, been trying to get mine running, starts on choke, revs like billiou then just dies, wont idle or anything, think carbs need balancing or something, am working on it..... been banned from buying the paint as way into our overdraft apparently..... but am sure there was a stall selling paint cheap last year so may well have a memory lapse when there.....[:D]
Postby nervousnewowner » 24 Apr 2011 14:08
oh and sad i know folks but will be wearing my tr7 t shirt so will be easy to spot......... easy ish, so feel free to say hello and intoduce yourselves, will answer to nervous or dave.......[:D]
staningrimsby
Postby staningrimsby » 24 Apr 2011 17:37
I'm gutted Dave i really wish i was going [:(], but got to try and get Polly ready for Friday im itching to get out in her [:)].
I'm also saving the polo shirt i got from 'Ruddy' until i can get to one of the shows, i tried it on when it arrived but it has hung in the wardrobe ever since.[:(]
1980 2.0 16v DHC - Polly.
Postby nervousnewowner » 24 Apr 2011 18:20
was planning on taking the tr tomoro too even though still multi coloured but bloody thing starts with choke out fully so revving guts out of car then just dies, been working on carbs so dunno if screwed something up or they now need setting up properly........ [:(]
staningrimsby
Postby staningrimsby » 24 Apr 2011 18:47
You will get there Dave,
It just takes a little persistance, trust me i know.[;)]
prlee
Postby prlee » 24 Apr 2011 19:05
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by trv8</i>
I got there very early last year and was able to park in the supermarket car park [:)]. Just get there as early as you can and you will have no problem parking.
Which supermarket do you use, I will be coming from Gloucester on the A4136, prob looking at car park A on the map. Plan to go home through the forest of Dean and over the old severn bridge.
Pete
81 Carmelian Red DHC
79 Pageant Blue Spitfire
Image Image Image
prlee
Postby prlee » 24 Apr 2011 19:08
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by nervousnewowner</i>
Could it be an air leak? do you have K&Ns and sealed the connection from the manifold to the old airtemp sensor?
Pete
Image Image Image
Postby nervousnewowner » 26 Apr 2011 07:43
k and ns were on the car when i got it, but the rubber mounts had split, when i took the old ones off there were NO gaskets fitted!!!! so refitted them with gaskets and also have cleaned the dashpots and pistons as one was sticking and now it starts on full choke, revs really high but will then just die, am hoping due to lack of gaskets originally the mixture was set really rich and just needs resetting to run properly.
its just finding the time to do it, ie dont finish work til 8pm tonight......... lousy retail work....lol
did you make coleford? was good day, didnt see lloyd, just heard him leaving.........lol
trv8
Postby trv8 » 26 Apr 2011 13:04
[quote]<i>Originally posted by nervousnewowner</i>
[:D] [}:)] [}:)] Glad you heard me Dave [}:)] [}:)] [:D].
The stewards made me park around the back of the supermarket out of the way this year [:(].
Walked past the TRs twice and hung around for a bit, but didn't see you about [:(].
Got bored so I jumped in the Beast and went for a blast [^].
prlee
Postby prlee » 26 Apr 2011 18:02
I take it that was at the back of the co op, in that case I think I heard you leaving.
I stopped at one of the out of town carparks and got the bus in, they ran every 30 minutes, the bus was an old route master. Impressed with the range and number of cars, not enough TR7's though. Travelled in from the Gloucester direction - great drive, little traffic and great road.
Left at 2.00 and came home via Monmouth and Chepstow, bit tedious stuck behind a car that thought 40mph was quite fast enough, he eventually turned off. Then across the first severn bridge and up the M5 to home.
Pete
Image Image Image
trv8
Postby trv8 » 26 Apr 2011 19:01
Yes Pete, that was me behind the CO-OP [}:)].
Seems to be less TRs there every year [:(].
I went the Wye Valley route home aswell [^].
zoe
Postby zoe » 26 Apr 2011 20:56
sorry i didnt see u there !! was there a NASTY GREEN Jensen there Dave ?
prlee
Postby prlee » 26 Apr 2011 21:26
Noticed one next to the disabled car park near the autojumble.
Pete
Image Image Image
Postby Hasbeen » 26 Apr 2011 23:52
Nervous, applying the choke in an SU is actually lowering the main jet, in it's tube.
This is what you do when you richen the mixture, by winding the mixture adjustment nut down.
So, if it will run with the choke out, it will run with the mixture adjusted richer.
Wind the mixture nuts right up tight, [lean], then wind them down 12 flats each, [2 full turns], this is the standard starting point for tuning.
If it still wont run, without choke, after warming up with some choke, just keep winding the mixture nuts down each the same number of turns, until it will run.
Check for equal suction, just with a hose in your ear, you are only tuning idle suction when you adjust this, & it doesn't matter very much.
When you get it running, without stalling, remove the dash pots, & check how far down each jet is. If one is much lower than the other, the inlet tract, with the low jet, is probably sucking air somewhere.
Stop being frightened of SUs, they are simple things, designed for us simple people.
Users browsing this forum: No registered users and 220 guests
