Running in
r4gwoods
Postby r4gwoods » 30 Jun 2010 17:34
We had the oil gasket on the water pump leak when we switched to the weber carbs set up and replumped the crank ventilation. We were not getting the internal air out of the engine and it blew right through the lower oil seal on the water pump. And seaped from the base of the distributor. And at very high rpm, came out the dip stick.
Just some more ideas thrown out to you for meditation.
Robert
1979 TR7 DHC 2 Litre SCCA Autox F Street Prepared
1979 TR7V6 DHC Buick 4.1 Litre Future Autoxer in X Prepared
1979 TR7 2.0 DHC Stock
1977 TR7V8 FHC Street
Autox pics from San Francisco Region USA:http://www.WWRacing.net
http://www.wwracing.net/photos/SantaClara5_10/32.html
Bobbieslandy
Postby Bobbieslandy » 30 Jun 2010 21:45
My crank case ventilation goes straight to atmosphere, there's no blockages and it all seems sweet in that respect. The reason for the leak is the smaller diameter on the water pump shaft after i turned a small amount of corrosion off. We're talking a miniscule amount, but just enough for it to let by. I'm going to put up with it now as it's too late in the project to rectify it. I'll sort it in a month or so.
r4gwoods, My crankcase ventilation goes straight to atmosphere and where it used to feed the carbs i've piped them together. She's all free to breath!
I think that what ever oil we use, as long as it does 60k without knocking the bottom end out then it's all good.
Postby FI Spyder » 01 Jul 2010 02:54
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Bobbieslandy</i>
You've got to aim higher than that.[:0]
I've got 90,000 miles on mine and it doesn't burn a bit of oil. I'm aiming for 190,000 miles lke that guy in LA got in 1995!
Bobbieslandy
Postby Bobbieslandy » 01 Jul 2010 04:08
I'll be dead before i hit 90k. 1700 miles in 4 years so far.......
Users browsing this forum: No registered users and 253 guests
