Darren Motamedy
Postby Darren Motamedy » 22 Dec 2011 00:25
I'm in the same boat with many of the forum...I bought new struts from Victoria British a couple years ago and now they don't work. I do have a luggage rack.....I don't care though.......it is what it is......at least my tr7 runs now, which wasn't the case this summer.....
dmo
mb4tim
Postby mb4tim » 22 Dec 2011 02:13
it would be interesting to find a gas strut that worked on the mechanical mounting points.
On MGB's, many people try to help by closing the trunk, only to bend the trunk lid by not pushing the stop that holds it up. There's a retrofit to convert that to a pair of struts. The trunk lid stand proud, and easily closes. There's a hood set, and a hatch set for GT's, as well.
I might have to compare the MGB and TR7 supports... maybe they're interchangable.
-Tim
mb4tim
Postby mb4tim » 22 Dec 2011 02:36
Would someone take a couple measurements for me? I have the lame, dead struts.
Based on Beans's photo (I hope it's OK to use this as an example, if not, let me know), please measure...
<ul><li>the distance, center-to-center, of the mounting screws.</li><li>the length of the lower, outer section</li></ul>
I think I have a bright idea... Is this the same part as the hood/bonnet support?
-Tim
Postby Odd » 22 Dec 2011 05:07
Nope.
mb4tim
Postby mb4tim » 22 Dec 2011 11:27
Nope.
D@mn! That would have made it easy. I saw that all four Moss part numbers were different (MGB and TR7), but I wonder just how different the parts really are.
-Tim
mb4tim
Postby mb4tim » 22 Dec 2011 22:17
the MGB trunk support has the same size lower bar, but the total length is an inch shorter. Looks like I might have an alternative to the lift-and-lock hood support to a pair of modern gas struts.
-Tim
Stag76
Postby Stag76 » 23 Dec 2011 06:29
You can adapt them...I'm using a Herald boot stay on my TR7 boot.
TR7 Convertible
Sprint Motor
MegaSquirt EFI
mb4tim
Postby mb4tim » 23 Dec 2011 11:38
I would, but I don't know how long the TR7 trunk lid prop is.
-Tim
Postby Odd » 23 Dec 2011 11:51
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> I don't know how long the TR7 trunk lid prop is. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> 485mm bolt centre to bolt centre...
mb4tim
Postby mb4tim » 24 Dec 2011 21:48
[quote] I don't know how long the TR7 trunk lid prop is. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> 485mm bolt centre to bolt centre...
Thanks Odd!!!
-Tim
nytebyte
Postby nytebyte » 08 Sep 2012 12:42
For some reason mine is missing. Any idea where in the USA I could find one with all the hardware? Ive tried ebay with no luck. there must be a scrapyard or something that would have one but dont know where to start. Maybe someone has a parts car that would sell one for a 1980 TR 7 DHC? Thanks for any help, Jim
Milanoverde
Postby Milanoverde » 08 Sep 2012 12:57
The '80 has 2, 1 on each side. I got mine from Victoria British. Tony
TR7 Boot / Trunk Gas Struts XKC 3893
Postby Hasbeen » 08 Sep 2012 13:04
Jim, are you talking about the twin struts, fitted to the hinges, that aid in lifting the boot/trunk lid, & hold it up, or are you talking about a prop similar to the one that props the bonnet/hood open?
The prop is not a standard item, but is fitted by many when the struts loose their oomph too often.
Ianftr8
Triumph TR7 Boot / Trunk Gas Struts XKC 3893
Postby Ianftr8 » 08 Sep 2012 15:57
If you are getting them from the scrapyard and you can find more than one set - its worth doubling them up.
This helps them out a bit and they seem to last longer.
Ian
Ian Freeman
1979 TR8 DHC
Triumph Courier
Triumph owner for 31 years
Darren Motamedy
Triumph TR8 Boot / Trunk Gas Struts XKC 3893
Postby Darren Motamedy » 08 Sep 2012 17:22
http://www.victoriabritish.com/scripts/ ... px?page=15
The link for the hydraulic struts, which do wear out fast....
on the same catologue page for Victoria British is the sliding trunk support......part #44.
I don't know how to attach this to my 1980 FI Tr, but I'm sure you could figure it out. To be honest with you, when my trunk is straight up and down in the open position there is no weight on the struts, so I don't worry about it crashing onto my head.....the hydraulic struts were a challenge for me to get in too....time consuming........not technically hard.....
dmo
