wide fender flare
grndsm
Postby grndsm » 15 May 2008 19:29
That can gain you 1-2" but you are now talking about a really crazy wheel off-set (probably over 55mm) and it isn't gong to be easy to find.
However, using a narrower rear axle might work [;)]
Leon
Postby Beans » 15 May 2008 20:27
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by grndsm</i>
[quote]<i>Originally posted by Graveshaker</i>
...I can't fit 7" wide wheel with 205 tire on my TR7 without "rolling" of the inner fender! <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Sorry have to disagree there [8)]
15x7" wheels with 205/50 tyres.
It's a tight fit OK, but no problems with the standard wings
Reddragon
Postby Reddragon » 15 May 2008 21:41
Graveshaker
Have NFI on either of these places.
If you keep checking Ebay under tr7, every now and then there is a fellow that lists a 1" thick adapter for 7's to 4x100 mm. He usually wants $ 225. plus shipping. It comes with the lugs, you must state you want it for the 7 as he also sells the same thing to spitfires.
Remember the the Spits use different size lug bolts.
A site I found that lists an adapter is adaptitusa.com It has been a while since I checked them out. Do remember that they sell an adapter for the 7. Search by bolt size.
Dale
1974 TR6
1977 TR7 FHC
grndsm
Postby grndsm » 15 May 2008 23:55
There are vendors on EBAY who sell the same kit for $135... They do not list our size, but if you ask for it, they will make a custom set for the same price!
Beans, you can't disagree with my results, it is what it is [;)]. However, you can point out that it has worked for you due to a different offet [:D].
Are you sure that your tires are not rubbing? It almost looks like you have a dark "rim" where it might be touching the inner fender! Do you have a close-up photo?
Leon
Postby Beans » 16 May 2008 10:28
Only one side slightly touches at the rear (RH) and only under extreme conditions. It doesn't even show on the tyre wall. That's due to the axle sitting slightly offset to the right.
ET of these wheels is 24.
But I have the same "problem" on my DHC which has 195/55 section tyres aslo on 15x7" wheels and an ET off 25 mm.
We just have to face the fact that TR7's aren't what you'd call welded together carefully [}:)]
Reddragon
Postby Reddragon » 17 May 2008 13:21
Grndsm
Would appreciate a little clarification where or under what topic you found the vendor for the adapter on e-bay.
I did a search under wheel adapters and came up with way to many. Tried to condence it to 4 x 100mm and came up with 4. None of these appeared to be what you mentioned.
Maybe I am just not looking in the right area. Can you help me out?
Thanks in advance.
Dale
1974 TR6
1977 TR7 FHC
Postby jclay (RIP 2018) » 17 May 2008 14:05
There is a kit that will let you move the mounting points for the shocks inboard several inches. Now you can use wheels with a deeper inset allowing bigger tires. I can't remember who supplies and have searched through all my bookmarks trying to find it. I have posted the photo here before for Apex - Kyle.
