lugnuts
Peter Nuss
Postby Peter Nuss » 04 May 2008 15:57
Do yourself and the other people on the road a favor and buy the correct lug nuts. You could put wing nuts on those wheels and I guess they would work too, but, they were designed for one specific style lug nut, with a shank that centers the wheel, and a flat washer to spread the load. Anything else is not correct. If you want a different style after market lug nut, take the wheels to a machine shop and have them milled for a press in steel insert that will properly fit an after market lug nut. I think you'll will find the stock lug nuts much cheaper than doing that. In my view there's much better places to try and save a little money than mis matching wheels and lug nuts. Anyone that sells these wheels (Rimmers, Vic Brit, etc) has the correct wheel lug nuts, there are not the hard to buy. Also, there are a lot of used ones around from all the people that put the much improved stainless steel ones on their car when they were being made in GB by a forum member. The earliest of these wheels are 32 years old, have been over torqued I'm sure several times, have microscopic cracks, etc, why stress them more with the wrong nuts. Rant over.....
TR8
Postby Beans » 04 May 2008 17:53
Yes, but you can't get around the fact <u>the design</u> was created for the TR8. Hence 'TR8 alloy rims'<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
You seem to forget that the few TR7 Sprint's that where built also used these wheels'[:p]
All the pictures I have of the prototype TR8's all have steel wheels [8)]
Postby Odd » 04 May 2008 19:49
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> You seem to forget that the few TR7 Sprint's that where built also used these wheels' <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> Yes, I forget (knowingly!) about those few cars - since they never made it to the mass market.
When Dave Keepax designed the rim it was for use in the TR8. Some of the TR7 'specials' also benefited
from this. Later it was thrown upon almost all the fixed heads - as a means of helping their sales, since
(just as nowadays!) people reasoned; "Why on earth should I buy a fixedhead when there's opentops
to be had?" So they had to sweeten the fhc deal somewhat... [;)]
humanoid
Postby humanoid » 05 May 2008 03:21
On a similar vein, does anyone know the torque for these lug nuts on alloy wheels? I'm guessing they should be about 85 ft/lbs.
Postby Beans » 05 May 2008 10:57
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by humanoid</i>
...the torque for these lug nuts on alloy wheels? I'm guessing they should be about 85 ft/lbs <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Indeed pretty close, the book says 120 Nm (or 88 lbf ft)
black_1980_tr7
Postby black_1980_tr7 » 05 May 2008 11:57
the lug nuts I referenced in an earlier posting also came with a set of chrome/ zinc/ nickel plated washers.
Howard722
Postby Howard722 » 05 May 2008 12:20
For the record, my 1981 TR7 glovebox manual only shows the Triumph alloy whels with 185/70 HR 13 tyres.
No mention of steel wheels.
I attach a pic. of one my wheelnuts so you can see the factory standard shape which uses a large flat washer that is semi-captive (by way of three swage detents in the washer) to the nut with a chrome button top finisher. I had my nuts `blacked` [:0]( no jokes please ) and refitted the chrome buttons which are a tight press fit about 20 years ago and whilst not concours now-they do the job!
Many years ago at a car show I happened on a bag of the correct nuts and washers as shown but these had been zinc plated but somebody had then lost the chrome finishers[:(] -I was happy to take them and fit my finishers as and when. I still have them and the bag contained 16 nuts&washers!
<font face="Comic Sans MS"></font id="Comic Sans MS">
[img][IMG]http://i267.photobucket.com/albums/ii304/trfrazz/TR7wheelnuts.jpg[/img][/img]
Enjoy& regards Image
humanoid
Postby humanoid » 05 May 2008 18:18
Howard, I have the exact same lug nuts that are the right-most as in your pics. Thanks to another member on the board. I'm just going to replace them with the Gorilla brand #72137 12mmx1.5mm "short shank" type. I'm not looking to restore the 7... yet, just trying to make her drivable for the time being.
