I have just taken the opportunity to remove my plenum panel for cleaning and have made note of the specifications of the original rubber blocks for future reference, since it is unlikely anyone may ever come across original replacements.
The flexible Unipart rubber blocks adhered on each corner edge of the panel consist of two shaped pieces each side that are sandwiched together with contact adhesive. The individual pieces for one block each side consist of two 8 mm thick slices of flexible rubber (total thickness glued together 16mm). The five edges of the dimensions are...
UK RHD Offside sandwich (individual pieces 8mm thick)
94mm x 59mm x 42mm x 52mm x 39mm sandwiched with
94mm x 42mm x 37mm x curve cut (The overlap is where the contact adhesive is applied to adhere to the plenum panel INSIDE edge).
UK RHD Nearside sandwich (individual pieces 8mm thick)
85mm x 59mm x 42mm x 38mm x 47mm sandwiched with
85mm x 42mm x curve cut (Overlap is again where the contact adhesive is applied to adhere to the plenum panel INSIDE edge).
A large T-cutting aperture slit (see photo) is sliced into the centre of each side for bonnet release cable and wiper motor rack piping. Nothing is actually cut out of the slabs. It is only the slit that angles out to allow through the piping and cable as necessary.
It should be noted that with these blocks fitted correctly, it is extremely difficult to even refit the plenum panel back on the car!
