Clock stopped working
Postby Odd » 21 Feb 2008 15:34
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> Unusual I know but I happen to like a clock in my car.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> Alan, you're probably like me, I also want a clock. I want this since I want it to look original to the casual
viewer. The oil pressure gauge will be found in another location where it will look OK, and still not look
as an afterthought or worse yet; a DPO hack...
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> Mine stopped working last autumn. I recently had the dash apart to replace the (non working) instrument lighting with LED bulbs. While the dash was in pieces I had a number of trials to get the bulbs working, connecting the battery each time. Lo and behold the clock started working again. Put the whole lot back together and switched on - lights work but the clock has stopped again! <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Your clock sounds like a prime candidate for Gregs fix.
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> Odd, is there a copyright on the method or is it available to thoses of us who don't belong to the TR8CCA, which I assume is an american organisation? <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> It will be available to most people needing this. An older version have been published by Greg Bober
himself at http://www.smallscalerailway.com/tr7_clock.htm and there you will find most of the important
info. The TR8CCA version will have better graphics I understand...
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> (as a side issue why do white LEDs shine blue through a green lens???).<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> I had similar experiences when I did the LED swap to my car, later I heard that you need to use the same
colour LED as colour of the shine-through filter if you want a perfect result. I fitted red LED lights to all the
red positions [N.B! <u>bar</u> the ignition light where it's important with both ways conductivity, something LED
lights are incapable of...] and then two green LEDs to the direction indicators and a single blue one to
the main beam indicator. They all work like a charm. Unfortunately I haven't been able to locate any
Amber T5 LED lights - so the tank level warning light is still an ordinary bulb. If anyone have a lead on
amber T5 LED units I'm willing to swap for red, green or blue ones [that I have in surplus]...
/Odd
Postby saabfast » 21 Feb 2008 22:24
Thanks for the clock reference, I'm not much of an electronics expert but will study it and visit Maplins.
I changed the bulbs to LEDs following a thread here as when replacing the bulbs previously it was obvious that the heat had been melting the bulb holder mounting areas. This only applies to the backlighting as the warning lights are not on for very long. I will have to see if the ad on ebay lists green lights (better postal service from HK than from the UK!), although the blue did not look bad but does not match the rest.
Postby UKPhilTR7 » 22 Feb 2008 08:21
<font color="green"><b>One thing I was thinking of doing was putting a light in the centre console so that a light is shining down on to the gear stick area. I got the green lense and bulb holder all ready to make the holes, but thinking about it, the better option may be to go to Maplin and just get two green LEDs and holders and put them in. But in saying that would it be possible to fix the LED's so that they work with the dimmer switch and go up and down with the rest of the interia lights? </b> </font id="green">
