TR7 Headlamp Flash CCT & LED headlights
Howard_B
Re: TR7 Headlamp Flash CCT & LED headlights
Postby Howard_B » 26 May 2020 22:23
Cobber wrote:Bin the shitty old type flasher unit and go for one that will work with your LEDs if you must have them, I see no point in fitting LED bulbs in the indicator circuit, if you have to go to the trouble and expense of fitting ballast resistors into the circuit.
It defeats the purpose of lower wattage LED bulbs if you have to fit ballast resistors to up the wattage just to get the damned things to flash!
Hi Cobber
You don't need to fit ballast resistors so long as you replace both flasher units installed on a TR7. Most of us have replaced the indicator flasher as its easy to access and routinely causes problems with the flash rate due to bad earths, but since the hazard flasher is stuffed away behind the glove box and doesn't normally cause any problems its not replaced.
The main reason for swapping the lights to LED's is to reduce the electrical load & the resistors (4 No 6.8 Ohm / 50W) was a temporary solution until I changed the hazard flasher.
H
supercass
Postby supercass » 27 May 2020 06:05
Don't the EEC regulations state that you must have a warning system to let you know in the event of an indicator bulb failure?
supercass
Postby dursleyman » 28 May 2020 15:00
supercass wrote:Don't the EEC regulations state that you must have a warning system to let you know in the event of an indicator bulb failure?
supercass
On moderns maybe, but they were certainly not fitted on our 40 year old cars.
Postby busheytrader » 29 May 2020 06:46
+1 for the electronic indicator / flasher unit - not slowing down at junctions
"Shit on the liver" :?:
Postby Cobber » 29 May 2020 12:21
busheytrader wrote:"Shit on the liver" :?:
= A cantankerous, grumpy, foul tempered disposition
'80 Triumph TR7.
'98 MG-F.
'83 Jaguar XJ6 Sovereign S3.
Users browsing this forum: No registered users and 22 guests
