TR7 Cruise / Marker Lights and Covers TR8
Postby gaz » 13 Apr 2015 17:52
Ha ha cops chasing TR7's who would have thought it
you can read all about it in Andrews book[;)]
1981 DHC 2.0 Litre
1980 DHC pedal car
seven
Postby seven » 13 Apr 2015 18:04
It didn't help that I was dressed in dark blue and white shirt [:D]
Triumph TR7 DHC
Triumph 2.5 Estate
Triumph 2000 Saloon
Mercedes 320SLK
Jaguar X-Type Estate
Kawasaki GPZ
supercass
Postby supercass » 14 Apr 2015 20:44
Marker lights as per export P6 Rover 3.5??? supercass
Postby john 215 » 15 Apr 2015 04:24
A quick look at NAS P6's and they look more square ?
The only one I cam remember seeing lately but again poss not the right shape is a NAS Mk1 Capri last year at a local show -
It at least has the chrome surround [:I]
Postby FI Spyder » 15 Apr 2015 13:42
Personally I like the understated N/A lights. Unfortunate you guys just got the blanking plates, looks so unfinished. Don't blame you for changing them out. It's not contravening any silly local laws is it?
supercass
Postby supercass » 15 Apr 2015 15:53
Believe it was when the cars were new hence they would never fitted to UK cars. supercass.
Postby silverseven » 16 Apr 2015 00:13
oddly enough I like the understated blanking plate .....and might fit them one day if I were to find some locally.
Postby Odd » 16 Apr 2015 12:44
The reds on the rear wings aren't allowed (lit) in the EU
- we have to change them out for the amber version for the front wings if we want to have them lit.
/Odd
Postby Cobber » 16 Apr 2015 13:24
Here in Oz they should be amber in the rear too, and they should all be connected to the indicators not the parking lights.
'98 MG-F, 69'Ford F250.
DutchTriumph
Postby DutchTriumph » 16 Apr 2015 13:31
In The Netherlands the rear can be red , if the car was build before 1991.
At first it was a problem at the MOT, but after examining the rules it passed MOT.
Peter
Postby Maxwell » 16 Apr 2015 15:23
They don't look right on the Capri.... IMHO!
toneinblack
Postby toneinblack » 16 May 2015 15:15
just been checking my lights and the 2 cruise type lights on the front don't work , ( the two red ones on the rear wings both come on with the rear lights ) so I had a look underneath and apart from missing bulbs and old wire and old white connecting blocks it looks like it needs to be redone, the old wires ( green indicator wire and red sidelight wire) have both been cut along with the black earth to the indicator and plastic white connector blocks have been used with wires hanging out and none of the ends are live even tho the proper indicator and side lights work fine, so ill strip the old stuff out and use spade connectors to rejoin but if I do it the way it look like its been done then when I have the sidelights on and use an indicator what takes priority ? or should I just use the indicator wire and not the sidelight,
How have you got yours?
Re: Front wing orange lights,
Postby dursleyman » 16 May 2015 15:32
I have mine wired into to indicators so they flash together.
Not sure if showing orange with sidelights at the front is legal in the UK?
toneinblack
Postby toneinblack » 16 May 2015 15:42
im tempted to just have them as indicators like newer cars have them, seem some combinations on facebook where they seem to have everything wired in to them.
supercass
Postby supercass » 16 May 2015 15:52
I have mine wired to the indicators. I believe that is far more useful than using them as marker lamps. I believe it is possible to have them working as marker lamps and indicators but I understand that involves fitting an additional device / circuit presumably to prevent the front and rear sidelights from flashing also. I seem to recall some 70's American cars had such a system (and perhaps more modern ones). I would just keep it simple myself! supercass
Users browsing this forum: No registered users and 83 guests
