Not about a TR7 But Help required STAG
Re: Not about a TR7 But Help required STAG
Postby Hasbeen » 04 Feb 2020 00:30
I had a problem with the fuse board early on.
Some fuses were not passing current even though the contacts on the board were clean & bright as were the fuses, which tested good. I sprayed the board contacts with contact cleaner, & replaced the fuses. All working, well for about 8 months, when the problem returned.
This time I used a microfibre cloth & contact cleaner, & gave everything a good rub.
That was over 10 years ago, & the problem has not returned.
bonnietiler
Postby bonnietiler » 05 Feb 2020 18:21
All fully functioning now..many thanks for all tips and suggestions
Regards
Brian
Postby busheytrader » 07 Feb 2020 13:07
Brian,
Do you know where the problem was?
Postby Hasbeen » 07 Feb 2020 13:32
Yes no secrets here.
bonnietiler
Postby bonnietiler » 10 Feb 2020 20:42
The Switch worked fine and the fusebox worked when given 12v so the fault lay between the Ignition switch junction box and the fusebox, so I connected a wire from the ignition switch directly to the fusebox, bypassing the break as it were and everything is fully functional now, although I am buying a replacement blade fusebox as the original is just that ...43years old and a little tired..Tr7V8 is behaving manfully of course, ( I only run old Triumphs) it has only ONE fault...in that it only has 2 seats, as such a poor vehicle for the school run and my 3 Grand-Children!
DutchTriumph
Postby DutchTriumph » 13 Feb 2020 19:13
My guess would be a faulty coil.
I’ve had a similar problem with my Spitfire. It started fine, but after a short drive the motor stopped, like no ignition (no sparks). After cooling down it started fine again. Changing the coil cured the problem.
Peter
