Head Honcho (Cylinder Head removal tool)
Re: Head Honcho (Cylinder Head removal tool)
Postby Beans » 05 Jul 2017 21:13
The main reason why the studs get stuck is contact corrosion between the steel studs and the alloy head.
All other problems just add up to it :wink:
Postby Hasbeen » 06 Jul 2017 09:38
It could be Oz conditions Beans, or perhaps I have just been lucky, but there was no corrosion in the couple I have done. In fact one still had oil on the studs & one grease. Neither had run in some time, so it was not fresh oil or grease.
In both instances, once cracked, they screwed out by fingers. I was surprised at this, as all the posts about head removal had reported considerable corrosion.
Postby Cobber » 06 Jul 2017 13:17
You should be able to order high tensile allthread rod from an industrial fastener supplier that caters to the engineering industries.
It's where I get all my fastening hardware from.
'80 Triumph TR7.
'98 MG-F.
'83 Jaguar XJ6 Sovereign S3.
Users browsing this forum: No registered users and 119 guests
