Gear Ratio Comparasions
jeffremj
Postby jeffremj » 12 Aug 2013 15:37
Okay, with the first few numbers in, let's start some analysis.
Nick with his supposedly 1980 LT77 and a 3.45 differential is at 2500rpm@60mph.
Russ with his 1980 LT77 and a 3.90 differential is at 3000rpm@60mph.
Hasbeen checks in with near identical numbers to Russ. We thank you.
That's a 500 rpm difference.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">My TR7 booklet mentions 20.8mph/1000 revs in 5th. Therefore Russ should be showing around 63mph @ 3000rpm.
Further to this, I found that my TR7 speedo was over-reading and so I fitted a different speedo cog. It had one more tooth and this slowed the speedo by around 5%. On my TR7V8, with 3.08:1 diff and TR7 gearbox, I managed to get a standard TR7 speedo to give very good figures when using the cog with the lowest teeth that BL made. Figures checked on a rolling road - 71 shown 70 mph true. Tyres were 205/50x15 - this has an affect!
Postby Beans » 12 Aug 2013 17:01
1980 TR7 DHC with correct 5 speed 'box in 5th gear of course, 3.45:1 diff and 185/70-13 tyres @ 2.1 bar cold
(and the speedo proved to be frighteningly accurate as the GPS was reading 120 km/h)
And doing 60 MPH can be dangerous in Germany [:p]
Postby Workshop Help » 12 Aug 2013 18:45
Please, allow me to convert your foreign KPH to the more civilized MPH; 120KPH = 74.5645MPH, per the Google conversion chart.
Will there be a posting of a photo showing the tachometer reading at a pokey slow 60MPH or 96.5606KPH for our comfort & convenience?
Postby Beans » 12 Aug 2013 19:12
60 MPH should be at around 2375 RPM.
Will check as soon as she's ready for the 10CR
Postby Beans » 12 Aug 2013 19:16
Please, allow me to convert your foreign KPH to <u><i>the more civilized MPH</i></u> ...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Opions on that vary a lot on the continent [:D]
Postby john 215 » 12 Aug 2013 19:31
Mine is 2.84:1 and a late higher 5 gear LT 77, 14 inch wheels equals 2000 rpm ish but not really applicable as you guys are talking 2 litre cars I guess.
1976 Speke FHC Beauty
Postby Workshop Help » 12 Aug 2013 20:05
We have a new winner: Beans! With a chugging low 2375 RPM's!
Who's next? I'm thinking a 3.08 differential with a late 1981 LT77 might get it on down to just over idle speed. I've always dreamed of slipping the 3.27/1 automatic cars differential into my rear housing. But, I never could find one.
You folks with TR8's need to get in on this as well in your own category.
Postby FI Spyder » 12 Aug 2013 23:54
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by nick</i>
I would say you have the 3.45:1. You have to jack the car and look at the bottom of the differential. Scribed (not stamped) will be a code. Here is the key:
5 speed 3.9:1 CH
5 speed 1980-81 3.45:1 CL
4 speed 3.63:1 CG
Auto 3.27:1 CT
You may have to scrape off some grime to find the code since it is scribed into the metal.
What do you mean by scribed? To me scribed and stsmped mean the same thing with the other type being "cast".
Postby FI Spyder » 12 Aug 2013 23:55
I think I need a six speed.[8D]
whitenviro
Postby whitenviro » 13 Aug 2013 03:11
I don't know what ratio have, so I was hoping this discussion would help me figure it out. With standard 185/13" wheels I noticed on my recent trip that in 5th gear I was at 3000 rpm at 70 mph. I don't recall ever traveling at 60 mph....
[/img]
Postby Hasbeen » 13 Aug 2013 03:25
Whitenviro that sounds to me like a standard 3.9 giving 62.5 MPH at 3000RPM, with the usually 8/9% fast speedo.
All my 7s bar the current one were reading about 70 MPH at 3000 RPM, while I was actually doing just over 60. Have you ever checked it against a sat nav?
I'm sure this was most advantageous in preventing me getting booked on our mostly 100Km/H, [62.4MPH] speed limit roads.
Postby Odd » 13 Aug 2013 06:20
Please, allow me to convert your foreign KPH to <u><i>the more civilized MPH</i></u> ... <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"><blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Beans</i>
Opions on that vary a lot on the continent [:D] <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Second that!
And not only on this, the largest land mass/continents... [:)]
Postby silverseven » 13 Aug 2013 09:34
5 speed 3.9:1 CH
4 speed 3.63:1 CG
Auto 3.27:1 CT
Scribed as in chalk mark ??
My diff has been Ziebarted and painted , so I doubt this would be visible anymore...... I was hoping for a tag or as Spyder said a casting.
It's raining today , so I might take the wedge into the shop and maybe throw it up on the ramp and inspect the rear a little closer tonight.(who knows??)
Postby john 215 » 13 Aug 2013 10:10
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><font size="4"><font color="red"> I think I need a six speed.</font id="red"></font id="size4"><hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
How about one of these -
TR7 four speed gearbox, overdrive 3rd and 4th hey presto 6 speed box [:p]
Will be intresting to see what revs at 60 mph are ????
Postby nick » 13 Aug 2013 16:47
[quote]<i>Originally posted by nick</i>
5 speed 3.9:1 CH
4 speed 3.63:1 CG
Auto 3.27:1 CT
By scribed I mean written with a sharp objected as opposed to raised as part of the casting. The former gets covered by dirt and grime while the latter does not.
'79 TR7 DHC
'76 TR7 FHC
Users browsing this forum: No registered users and 189 guests
