Handbrake setup
Postby FI Spyder » 13 Jul 2013 13:30
Definitely tidy. Looks like you welded in a section. That would make me nervous even if it was welded correctly. (Just me). It would be nice if an L piece was stamped and ground down to shape or there was a part from another car that could be adapted. Need to wander around an auto wreckers for a couple of days.[:p]
darrellw
Postby darrellw » 13 Jul 2013 14:27
So perhaps I'm lucky that my handbrake seems to work great, or maybe I'm just used to the gorilla pull that my TR4A needs. But wouldn't lengthening the levers on the drum end mean you would need more travel at the handle? Or is there already plenty of travel there?
Darrell Walker
66 TR4A IRS-SC CTC67956L
81 TR8 SATPZ458XBA406206
Vancouver, WA, USA
Postby dursleyman » 13 Jul 2013 19:02
Daryl consider yourself lucky if your handbrake is still good.
I guess mine had just got a bit stiff in the joints - a bit like the owner.
Found a new problem now, a bit more familiar.
1980 TR7 Sprint DHC
Stag76
Postby Stag76 » 13 Jul 2013 20:25
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">So perhaps I'm lucky that my handbrake seems to work great, or maybe I'm just used to the gorilla pull that my TR4A needs. But wouldn't lengthening the levers on the drum end mean you would need more travel at the handle? Or is there already plenty of travel there?
Yes, you do get a bit more travel...probably 2 or 3 clicks of the ratchet.
TR7 Convertible
Sprint Motor
MegaSquirt EFI
Postby Odd » 14 Jul 2013 10:52
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> Definitely tidy.
Looks like you welded in a section. That would make me nervous even if it was welded correctly. (Just me). <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> Not me - remember nuclear rector tanks are welded up as well.
As long as it's done correctly there's no extra risk with welding metal pieces together.
And it's only one weld in each arm...
Users browsing this forum: No registered users and 182 guests
