Rear brakes
Postby Workshop Help » 01 Feb 2013 23:04
To further clarify. All the four speed and the automatics thru the change in about 1980 or 1981 use the larger bore four speed brake cylinders. What happened was the automatics used the four speed axle assembly. At the end, to use the same rear end assembly, Triumph switched all models to the five speed rear end and changed the internal ratios to suit the transmission being used. Where the five speed had been 3.90:1, it was altered to 3.45:1 with an additional change to the fifth speed gear set in the gearbox. The automatic rear end ratio was changed from the old 3.27:1 to 3.08:1, the same as on the TR8.
So, in your case, the four speed and automatics brake cylinder is the same when using the early series rear axle assembly. Please refer to your reference materials such as the V-B catalog, The Roadster Factory parts catalog, the Rimmer Bros catalog, Rockauto.com online catalog, and any other source you can find in order to ascertain the correct part needed for a given repair. Otherwise you will wind up with a useless parts inventory.
Postby nick » 02 Feb 2013 14:48
Well then. That is good news. By shear luck I ordered the right part since the the supplier says the CENTRIC 134.30004 is for 75-80 automatics that makes it the correct for my 76 4 speed. Thank you.
Are you enjoying the Boysenberry?
'79 TR7 DHC
'76 TR7 FHC
Users browsing this forum: No registered users and 199 guests
