EZ Power Steering
Bendder
Postby Bendder » 17 Jan 2013 03:18
That would be my take on it as well. It could be numbed a bit if the amount of assist is turned up but having the ability to turn it down or even off would make it no different than stock at speed. I suppose if you wanted the one finger driving method at speed all you would have to do is turn up the assist which I assume would numb the feel a bit. If you wanted to go to a track day though and have full feel I think the answer would be, turn it off.
1978 TR7 FHC
Postby Hasbeen » 17 Jan 2013 03:50
Yes that sounds good, but I'm not sure if it really is like that.
The S2k is totally dead, no feel at all, although the steering response is brilliant. From a discussion on an S2k web site I gather that the only way to change it, is to pull the fuse.
The general consensus was that it made the steering pretty heavy, but did very little to induce any feed back into it. Depends on the system I suppose.
One bloke reckoned he improved things by removing the power gear, & making some fairly large changes to the geometry. Too much mucking for me. I'll just drive it as it came out of the box.
The thing is pretty good really. I never try to get closer to the limit than about 7 tenths in it. I think it would bite real quick if pushed. It's 7 tenths is about 9 tenths in the 7, but where you can nudge up there with the 7, & retreat back to safety, without it getting nasty, I think you are going backwards into the scenery before you know it, at least on the public roads, in the S2k.
I guess that's why I love the 7 so much. All I need now, is to get the damn thing back on the road.
Postby Cobber » 17 Jan 2013 07:03
<font size="2"><font face="Comic Sans MS">The MGF system is meant to turn off completely at 50 kmh, with the system fitted to the TR I'd be inclined to try having it turn off completely at @ 20 kmh as a starting point and adjusting it from there.
Since having had some serious hand injuries over the last few years, I'm not sure that I'll ever have the full use of my left thumb again (the 5th and hopefully final reconstruction operation next month)
So having steering that wont tire or hurt my hand will be the difference between a car that I can enjoy using and a car that will have all the fun sucked outta it.
The only cars that I've been able to use over the last 2 1/2 years are the one's with power steering. </font id="Comic Sans MS"></font id="size2">
'98 MG-F, 69'Ford F250.
dycecooper
Postby dycecooper » 17 Jan 2013 07:24
It has transformed the car, its fully adjustable, I have it set so it has just enough assistance to give it the easy of nipping into a parking space without having to do a muscle warm up first,
Yes you loose feedback if its turned full up, easy solution, don't turn it full up!
There is a pensioner in Aberdeen that recently fitted hydraulic power steering to his TR6, he hates it, it's too light and cannot be adjusted, at least with the electric system you can switch it off when out and about and back on in Town.
Personally, I have it on all the time as I have found the sweet spot in the setting for me.
Stag76
Postby Stag76 » 17 Jan 2013 08:04
I used a hydraulic system on mine. It's probably a little on the light side, but increasing the caster angle made it heavier at low speed, and helped it to track better at highway speed. Mounting the pump was the hardest bit. PAS and better brakes transformed the car.
TR7 Convertible
Sprint Motor
MegaSquirt EFI
Craig C
Postby Craig C » 20 Jan 2013 05:48
I have been investigating an EPAS modification to my TR7V8 and collecting parts for a few years now. I have both a Corsa C and MGTF EPAS column and ECU and have sourced a speed signal cable to, theoretically, provide a signal to the ECU from an LT77.
I have as well a digital pulse adjuster + hand controller to modify the signal to boost very low speed assist and dial out all assist gradually at a speed I decide.
I also have many more photos and links to articles etc and would REALLY like to see a "sticky" topic started dedicated to EPAS and the TR7. There's lots of us going it alone at the moment and it would be great to have all the info and expertise in one place.
How about it Jclay?
Craig
Tr7V8
PS The need for EPAS is because of the following, yet to be fitted:
and
Postby Cobber » 20 Jan 2013 07:09
<font size="2"><font face="Comic Sans MS">I didn't realise that Jaycar made a digital pulse adjuster kit for EPAS, it even has an image of a MGF on the label [:D] a coincidence that has to be a good omen for those of us intending to use the MGF EPAS!</font id="Comic Sans MS"></font id="size2">
Postby dursleyman » 20 Jan 2013 10:17
Dycecooper, a question please.
ref your Corsa column conversion, is it home brewed or is it available elsewhere?
I have seen a couple of adverts but you always wonder if theye are any good.
1980 TR7 Sprint DHC
dycecooper
Postby dycecooper » 20 Jan 2013 16:36
1980 TR7 Sprint DHC
I removed a column from a Corsa and adapted it with home made brackets, I retained the Corsa switchgear too.
wayne walsh
Postby wayne walsh » 08 Jun 2013 17:17
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Hugh</i>
Wayne,
I am in the middle of fitting a Corsa power steering system to my car, I have modified the top end so that it is still TR7.
It's taken a bit of time to measure everything up, but the amount of machining is minimal, most of the work was measuring up how and where to machine the parts.
There is still some welding up to do.
I have looked at the possibility of reducing the assistance below that of the control provided by the eBay boxes, but not concluded anything yet.
dycecooper kept the Corsa switchgear in his car which makes the mechanical part of the job simpler, he also reports that the eBay system is pretty good.
I have been caught up with other stuff recently, but will post up some pics of what the parts and the mock up looks like shortly.
Hugh
Any update on the Corsa system Hugh?
5.0 litre TVR Powered
Users browsing this forum: No registered users and 213 guests
