Everyone hybernating for the winter?
Postby Odd » 24 Nov 2012 08:08
The same can't be said for rad hoses so I would replace those of they are iffy since they are relatively cheap
and you don't want to blow one at an inopportune moment. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> Personally I would recommend changing the radiator hoses out for custom formed (stainless)
thin wall pipes connected at the ends with short pieces of proper straight (not curved) reinforced
silicone cooling hose. It's way less risk of bursting a 'hose', and you can accommodate almost
any strange routing/awkward bends with custom thin wall piping. Here's my lower radiator 'hose':
/Odd
moestr7v8
Postby moestr7v8 » 24 Nov 2012 19:59
Hi Odd
Good idea on replacing the hose where did you get the stainless ones from?
I have replaced mine with Samco hoses but I must admit the polished s/s are quite appealing.[;)]
Moe
KFSullivan
Postby KFSullivan » 25 Nov 2012 03:11
Put our away a few weeks ago. We were at 64 degrees F on Nov. 22, but the next day it was only about 30.
No snow yet, but will soon no doubt.
We have a nice warm shop to work in, so we hope to get some things done over the winter.
Postby Odd » 25 Nov 2012 05:01
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by moestr7v8</i>
Good idea on replacing the hose where did you get the stainless ones from? <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> I made it up from short pieces of prefab material. It was a necessity to get the radiator return around
the oil cooler piping, the radiator fan shield bracket, the (long version) oil filter and some other stuff
which forced very tight curves and a twisted routing which no hose would do without flattening out...
moestr7v8
Postby moestr7v8 » 25 Nov 2012 18:30
Excellent job Odd looks great on the car I would think definitly no problems with them deteriating.
Do you fancy making a few sets up for sale? [;)]
Moe
Postby john » 25 Nov 2012 19:14
Nope certanly not in hibernation just too damn busy trying to find work and then getting the buggers to pay for it [:D]
Postby gaz » 25 Nov 2012 20:56
As a result of me not hibernating my cars i had a little mishap today.....
Bright sunshine clear blue sky a chill in the air (not freezing)
I decided to put the hood down...... CRACK goes the rear window in two places plastic had gone brittle oops a quick repair with some roofers flashing tape but now either need a new hood or a replacement rear window[:(]
http://mytr7.weebly.com/
1981 DHC 2.0 Litre
1980 DHC pedal car
1976 FHC 2.0 Litre
John Wood
Postby John Wood » 25 Nov 2012 21:00
I've done the same in the past. £80 ish for a new back window Gaz.
1977 TR7 Sprint
Neil_W
Postby Neil_W » 26 Nov 2012 02:42
Saw this a while back - maybe a start - maybe possible to cut out the window carefully & use velco self adhesive tape on each part to inset the new plastic which will be hidden under the hood material flap with only bottom showing ( your hood being black won't show really )or glue in new section - cheap repair for the time being & watertight ?
Does say 'frost proof [;)]
http://www.ebay.co.uk/itm/MG-TRIUMPH-TR ... 333wt_1084
bula
Postby bula » 26 Nov 2012 08:09
Might pay to get a supply of that for when the inevitable happens or some jealous scally takes a blade to it [:(!]
As for driving in this weather, Sunday wasn't too bad so took the opportunity to have a quick spin around the lanes near me. Not much too look at, sorry, bit boring but have stuck it on youtube if anyone fancies a gander gave me [:D][:D][:D][:D][:D] anyway lol
http://www.youtube.com/watch?v=3jTxml_kDak
trekcarbonboy
Postby trekcarbonboy » 26 Nov 2012 11:46
Very nice Bula. Looks like some fun roads. And love that roar!
Craig '75 2.0 FHC
bula
Postby bula » 26 Nov 2012 19:21
Thanks trek, sounds even better from outside ha ha. Will try and get a better montage of clips put together as and when time allows but certainly won't stop driving it until absolutely necessary, just grin everytime Im behind the wheel!
Postby silverseven » 27 Nov 2012 00:17
ok...............that's it I want a V[8]!!!
Care to give us some specs Bula?
Postby john 215 » 27 Nov 2012 05:04
Hi Bula,
Good video [8D]
Got that carb / fuel issue then, what did you end up doing [?]
1976 Speke FHC Beauty
bula
Postby bula » 27 Nov 2012 07:51
Morning John, yeah in the end[:)] bit of tinkering but ended up running the Red top into a swirl pot in the boot, that feeds a Bosch type injection pump,filter, then into the Malpassi rising rate regulator. Return back to tank from both regulator and swirl pot. Seems to work fine at 3-5 psi + boost. Certaily no starvation issues, quite the opposite ha ha.
Silver, have done the usual mods most choose to do with the V8 conversion, uprated the suspension, but left std springs on the rear(thought it may give it more bite into the road) brakes are Vitesse 4 pots with vented discs, sherpa servo and M/C, strut roller bearings for steering (hate to think what parking would be like without them,I'm a 6ft 17 stone rugby player and its still a bicep workout at parking speeds!!![}:)]) behaves lovely at speed though and curiously, no wobble at 55!!![:)] 15" MGF 5 spoke alloys, full blended body kit (still have to fit the boot spoiler) functioning cruise lights, Front mounted intercooler, Powermax dizzy with Lucas sports coil, 8mm leads and of course the purring Rover 3.5 complete with Janspeed turbo[:D][:D][:D]
If you do decide to go down the V8 route and why not (you pay almost half of what we do for petrol!!!!) the forced aspiration devil WILL, show his ugly face, The wedge shop have been developing an off the shelf kit....nice!
She's taken two years of fannying about to get to this point but unfortunately I work nights so have to sleep when its light and could be tinkering, half the weekends out because of sport oh and not forgetting family stuff ha ha. Been done on a bit of a shoestring budget too, what I couldnt get I made and what I had to get new I saved my sparechange for. Watched Ebay like a hawk! Those new parts I mentioned, got them delivered when my partner was out working, squirreled them away for a few weeks to get dusty then, If she asked, it was like, Oh no love, these old things, had them ages look[;)] Dont judge me, Im sure we've all done it.... or are going to now ha ha
Users browsing this forum: No registered users and 248 guests
