Fuel Tank
zekow1
Postby zekow1 » 20 Nov 2011 16:20
I will take it out and decide then what I will do .
It seems easier to cut it in half and then welded back together.
as Odd showed us.
Just need a cut and then get it to a welder .
The cleaning and coating seems to messy.
If I could get an aluminun generic FI I might just go that way.
I'll keep you guys informed .
Thanks for the support as usual.
Rebuilding Engine
Postby busheytrader » 20 Nov 2011 16:51
You will make sure that there's not a hint of any gas fumes in that tank before you introduce any sparks won't you?[:0]
Postby FI Spyder » 21 Nov 2011 16:22
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by zekow1</i>
The coating isn't messy, it just drains out the bung back into the original can (see my sideshow link).
Not so with the cleaning part of it. Being in a rural setting I sometimes forget the challenges for our city brotheren. The city fathers probably won't look kindly on pouring that stuff down the drain. Not good for the alligators in the swamp.[:p]
tencate
Postby tencate » 22 Nov 2011 01:25
There are a few more photos on the TWOA FI fuel tank photo album (see Odd's post for the link). I worry a lot about using a coating and having it clog up the tiny 1/4 inch fuel fill hole in the swirl pot! It's looking like my recently cleaned and coated FI fuel tank has to come out yet again. This time no local guy it going to do it, I'll probably send it away someplace. Any recommendations near Santa Fe, NM?
Jim
Postby FI Spyder » 22 Nov 2011 01:33
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by tencate</i>
I can't remember if I had a piece of wire through it which I removed later or if I poked a hole in it before complete cure or if it never closed. The only way you have complete control of quality is if you do it yourself. Why do you have to remove it again? What happened?
Users browsing this forum: No registered users and 346 guests
