Front Sub-Frame Bushing Order
Postby Hasbeen » 29 Dec 2011 10:57
I find it easiest with the car sitting on it's wheels, with the front wheels up on my 12 inch ramps.
With the 8, if you undo all the nuts on the bolts a half an inch or so, the car will rise up off the subframe, lifted by the front springs. You can then remove one bolt at a time, replacing all the bushes in sequence.
This may not work quite as well with the 7, with it's different engine mount system on one side, but should still work with a little encouragement with a jack, & some cursing, at the appropriate moments.
darrellw
Postby darrellw » 29 Dec 2011 14:18
Thanks, Hasbeen!
Darrell Walker
66 TR4A IRS-SC CTC67956L
81 TR8 SATPZ458XBA406206
Vancouver, WA, USA
Users browsing this forum: No registered users and 376 guests
