16V rally car.
Postby Beans » 26 Jul 2010 17:48
If fitted properly (front lower then back) compression struts do help a lot against dive under braking.
It will also stiffen up the front because you don't have a bit of "flexible" steel bar acting as tension strut.
For attaching the ARB to the TCA (if fitted at all) I will be be using drop links.
Front coil overs indeed have a camber plate ...
As for the engine, not sure yet,
Will contact the guy who set up my current engine.
As he races Dollie Sprints he should have a solution [:)]
Otherwise I'll have to make up something ...
Bobbieslandy
Postby Bobbieslandy » 26 Jul 2010 18:18
Hi Alan,
I think that with the technology we have available now we can avoid many of the reliability issues they had back in the '70s. hopefully!
Rob.
jeffremj
Postby jeffremj » 26 Jul 2010 21:25
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">the Broadspeed Dollie BTCC racer developd 235 BHP @ 7750 rpm <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Almost as much as a standard Honda S2000 [B)] - another non-turbo 2 litre.
Bobbieslandy
Postby Bobbieslandy » 26 Jul 2010 22:21
performance Engine builders are getting Duratecs up to 375bhp and that's N/A. if i remember rightly thats @11000rpm[:0] Ok they're 2.3L but thats still a huge amount. There's no mention of uprated pistons, rods and crank on this super 16v, would the stock bottom end need changing for forged / steel items?
Rob
V8Wedgehead
Postby V8Wedgehead » 27 Jul 2010 11:31
I had a sprint conversion and it was an ex-John Buffum/Don Moore engine that with high compression, dual DCOE webers, header and special cam that resulted in 220hp and it would peg the tach wit ease. Around the town it was a pig below 3500rpms but over that it screamed!
Michael
Postby Beans » 27 Jul 2010 18:50
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Bobbieslandy</i>
... are getting Duratecs up to 375bhp ...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
For if I ditch the Sprint engine [:D]
Bobbieslandy
Postby Bobbieslandy » 27 Jul 2010 20:03
Is this one of yours Beans? I think that when turbocharged they're getting around 700bhp but i need to check that. Any idea what 'box is bolted onto it?
Postby Beans » 27 Jul 2010 20:24
It's an empty block from a friend, used for trial fitting for conversions.
There is a Sierra Cosworth T5 'box behind.
And it is a 2.3 ltr block, which is very tall indeed, for a TR7 I prefer the 2.0 ltr block.
Slightly more clearance at the top ...
Bobbieslandy
Postby Bobbieslandy » 27 Jul 2010 22:33
Did he have much grief getting the engine to mate to the 'box? i'm pretty sure the duratecs don't share the same bellhousing bolt pattern as the rest of the ford engines. It really is a superb engine though, i think my dinner weighed more than that engine does[:D]
Postby Beans » 28 Jul 2010 16:01
You can see the bell housing ...
Everything you want is available for these engines.
Marsu
Postby Marsu » 28 Jul 2010 16:50
Glad I'm broke at present because there is a brand new [url="http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=320564236066"]Ford Duratec 2.3lt Engine on ebay AU[/url] with opening bid of AU $1,750.00 (approx UKP 1k) with no bidders so far and only 1 day remaining.
But honestly, I don't think it be right to fit this to a wedge, given the potential to achieve high performance from the Sprint, while retaining the integrity of the original marque.
Bobbieslandy
Postby Bobbieslandy » 29 Jul 2010 15:02
My thoughts exactly. there's plenty of other engines which would be "better" but apart from a few mod cons the engine has to be a triumph. 700bhp + 11000rpm + TR7 though....Mmmmmmmmmmmmmm[:D]
Postby Shauniedawn » 29 Jul 2010 16:31
Don't understand all this homo stuff, but my Google alert came across this today...
4-cylinder TR7 homologation form
http://www.specialstage.com/forums/show ... p?p=360197
Shaun
Bobbieslandy
Postby Bobbieslandy » 29 Jul 2010 17:37
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Don't understand all this homo stuff<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> for christ sake don't search that on Google![:D]
That very same Gentleman posted it on here a few days back....
http://www.forum.triumphtr7.com/topic.a ... C_ID=12808
Postby Shauniedawn » 29 Jul 2010 21:38
Whoops - I missed that.
BTW - I promise I won't set up a Google alert for that!
Shaun
