LE MANS CLASSIC 2010
syol
Postby syol » 22 Feb 2010 19:30
Thank you!
Saw you the display of the TR7istes?
Who is not bad either
http://tr7.fr/crbst_56.html
http://www.tr7.fr
Howard
Postby Howard » 23 Feb 2010 12:44
There will also be Five TR7’s traveling to the event and camping with the TSSC from the North Wales TRDC area. Of the five cars two are rally reps - one in works V8 colours the other in sprint colours.
Triton7
Postby Triton7 » 24 Feb 2010 22:03
Howard
Do not forgot the one from the Midlands.
Simon B
TR7 DHC
Stag
205 CTI
syol
Postby syol » 25 Feb 2010 08:42
Houa!
For once ca are going to be the party of the TR7 in France!
Will be it the first time when he(it) will have so many TR7 there to gather in France!
Thank you has all!
http://www.tr7.fr
tr7jim
Postby tr7jim » 26 Feb 2010 17:08
syol,
Bonjour and see below a French TR7, which was parked near to the tetre rouge field.
I will be with Simon in the Triton Green TR7
Jim
HowardB
Postby HowardB » 27 Feb 2010 19:58
With all the TR7/8's attending it would be nice to arrange to get them all in one place for a photo shoot before or after the main event.
syol
Postby syol » 01 Mar 2010 08:20
Hello has all!
Yes it would be Marvellous
If have is one tens it would be good!
http://www.tr7.fr
tr7jim
Postby tr7jim » 01 Mar 2010 19:59
Syol,
Going by 2008 I spotted 4 french TR7 + other 20 other TR7/8, so you will see more than 10 easy.
Be nice to meet you all in July
Jim
syol
Postby syol » 02 Mar 2010 08:33
Thank you Tr7jim
but among my members only 5 / 33 answered present!
But more have it be better is!
http://www.tr7.fr
Postby gaz » 02 Mar 2010 19:17
syol i've just looked at your site for the first time looking good nicely laid out very fresh looking
syol
Postby syol » 08 Mar 2010 10:24
Thank you very much,
It very please me!
Syol
http://www.tr7.fr
syol
Postby syol » 24 Jun 2010 08:39
hi !
You come what day on the circuit?
Know or you will be place?
tank you
http://www.tr7.fr
Triton7
Postby Triton7 » 24 Jun 2010 11:53
This will be my first Le Mans Classic and I really looking forward to it.
Simon B
TR7 DHC
Stag
205 CTI
Rust Restorer
Postby Rust Restorer » 26 Jun 2010 18:42
Hurray, Tickets have arrived today, excited, but also nervous as my car is still in the garage, had head gasket failure, was removed, machined, and put back together on Monday, pretty certain nothing was done incorrectly, however when running up to temp the timing chain snapped!! luckily only on tickover. Off with the head again to investigate, no damage to valves or pistons, guides, pallets and shims. Took cam off to checked valves moved OK. investigation showed jackshaft had seized in bore, evidence of a metalic substance built up on jackshaft at front end where it runs in the bore and burnt in to it, but bore is ok. Weird as oilways are clear in block and on jackshaft, No signs of any gear damage on water pump or teeth damage to water pump drive on jackshaft that could have provided debris. Had to take engine out to drift jackshaft out by removing core plug at gearbox end.
1980 DHC Cashmere Gold
1981 FHC Persian Aqua Blue
www.andys-tr7.co.uk
http://andystr7blog.blogspot.com
HowardB
Postby HowardB » 26 Jun 2010 20:29
Anyone travelling via Dover - I am on the 8 am Dover/ Calais Sea France sailing (their English breakfast is really good!
Users browsing this forum: No registered users and 27 guests
